Radiator Fan
Old 19 Nov 2012, 07:56 am
Default Radiator Fan
Hi, just purchased a PT (2001 auto) knowing it had the abs light problem, however just found out that the radiator is not working as it overheats when standing still.
Tried the aircon on check and nothing
tuned engine off and tried turning the fan by hand and it is solid
and does not move, not sure if this is the case or has it siezed?
many thanks Paul
Old 19 Nov 2012, 12:49 pm
Default Re: Radiator Fan
the fan should move freely when manually spinning it. for less than $100 usd, get a dorman fan from rockauto. from what i've heard, they have a lifetime warranty.
Old 19 Nov 2012, 01:00 pm
many thanks soyomb, I'm in the UK but will check to see if they are available here, normally anything in the states is the same price in the UK, also it was dark and I may have been pushing the guard
Old 19 Nov 2012, 04:05 pm
cruserdad1976's Avatar
the fan is a known issue with the PT if it over heats sitting its most likely the fan not coming on remember the pt does nto like to get to hot to offten
Radiator fan bogaz Tech & Performance Forum 1 21 Nov 2011 03:59 pm
When Should Radiator Fan Come On? duffner General Turbo Discussions 17 16 May 2011 08:49 am
Can I take out the A/C radiator? fduffy28 Tech & Performance Forum 4 30 Mar 2011 10:49 am
Radiator fan mash35231 Tech & Performance Forum 3 14 Oct 2010 09:38 pm
radiator again sandylolee General Turbo Discussions 1 27 Jun 2009 10:55 pm
