Heat control knob not working properly
Old 19 Nov 2012, 12:31 pm
Angry Heat control knob not working properly
Last summer a mechanic replaced the evaporator coil. The AC worked fine, but I didn't try the heater since it was a hot summer and didn't need it. Now that the weather is colder, I need the heat. When I turned the heat control knob to the hot position, the amount of fan air through the vent was substantially reduced and the knob bounced back to the heat neutral position when I let it go. As I moved the knob back to cold, the air through the vents increased. It was air speed was highest at the coldest position setting. I do get heat in the hot position and cold in the cold setting, so the temperature does change. It's just the reduced air in the hot position and the bounce back of the knob from hot to neutral. I'm wondering if anyone knows what would cause this.
Old 19 Nov 2012, 01:07 pm
Default Re: Heat control knob not working properly
That problem is caused by the wires that controls the doors inside the heater box. You may need to remove the console cover and knobs and see if the wire is stuck. If the cables are free, maybe your mechanic didn't lubricate the door mechanism and that prevents it from moving
Old 19 Nov 2012, 01:51 pm
OK thanks. I'm not sure how to proceed to remove the front panel with the heater knob, but I guess I can try. When I took it to the dealer, they wanted $150 just to investigate and if it's a stuck door another $800 - $900 to fix. I hope it's the cable and that I can get to it. Thanks again.
Old 06 Dec 2012, 12:08 pm
So I eventually had to take it to the dealer. It turns out that the mechanic who installed the AC evaporator, did not reinstall the heater core properly. It was blocking the hot air causing back pressure so that the heat control knob popped back. Plus the fins were smashed and there was a small leak. Set me back $1200. Yuk!
Old 06 Dec 2012, 01:11 pm
Wow that sucks !!!
Old 06 Dec 2012, 01:18 pm
Tags
heater switch, reduced air
AC Control Knob Lighting Bulbs paulrosenthal Tech & Performance Forum 19 11 Sep 2018 09:42 pm
Heater/AC Control Knob NightWing General PT Cruiser Discussions 13 07 Jul 2016 01:40 pm
Heat Defrost Control Help jasonw General PT Cruiser Discussions 7 11 Nov 2010 06:32 pm
p0441 - Evaporative purge flow system not working properly: A few questions logicalfrank Tech & Performance Forum 7 05 Dec 2009 02:43 pm
heat and fan control ~ what to expect on 1 and 2 ? frances General PT Cruiser Discussions 7 22 Dec 2004 09:09 am
