So much changing for no improvement
Old 19 Nov 2012, 01:29 pm
Cool So much changing for no improvement
Hi, so I currently own a 2002 PT crusier limited that i bought off a police auction. The mechanic at the auction said I would just have to replace the starter and it would be fine. I replaced the starter but the engine is still cranking but not turning over. I was also told by my local mechanic that it could be the crankshift position sensory. When I changed that, the engine went from cranking over to not doing anything at all. Any ideas on what it could be?
Old 19 Nov 2012, 04:03 pm
cruserdad1976's Avatar
Default Re: So much changing for no improvement
Im not sure how it can crank but not turn over????
and now it does nothing so is the battery still fully charged???? kind of sounds liek maybe the timing belt is not right how many miles???? auto stick???????
Old 19 Nov 2012, 05:34 pm
Bit confused myself on that one...
Old 20 Nov 2012, 01:48 pm
chris15's Avatar
Yeah, we need some kind of clarification on your definition of "cranking" and "turning over". Did you verify that you're receiving spark at all cylinders? If not, that points to coil, wires, or plugs. Crank or cam position sensors would result in a no-start condition.. Definitely check the battery though, too. Repeated long attempts at starting the car (turning the key, operating the starter) will drain the battery very, very quickly.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Tags
crank, engine, timing belt
CAMBER IMPROVEMENT LooseJox Wheels, Tires, Suspension 30 19 Sep 2012 07:05 pm
The $6 Improvement thegoldpt Exterior Accessories Forum 5 26 Aug 2005 10:26 pm
Gas Mileage Improvement aquarius69 General PT Cruiser Discussions 8 22 Mar 2004 05:52 pm
Stage I has given me a 20% improvement in mileage! mvandale Stage Turbo Kits 27 04 Dec 2003 10:04 pm
Performance Improvement Items mich_132003 Stage Turbo Kits 10 30 Oct 2003 09:52 pm
