Replaced Thermostat 06 PT Getting Engine Light ERROR P0128 Coolant Thermostat
Old 20 Nov 2012, 04:57 pm
Default Replaced Thermostat 06 PT Getting Engine Light ERROR P0128 Coolant Thermostat
So I recently Replaced my thermostat and flushed the system. The system was bruped. My heater doesnt get hot unless the care gets to about mid temp and that only happens on city street driving. My engine light turned on and I get the error code
My car constantly runs about 1/4 up the temp range and lower. I got a fail safe thermostat. Did I miss something when replacing my thermostat??? I Made sure the notch was in the right direction is there a way to reset the thermostat senor I took the battery cable off and the engine light turned off for a while and just came back on today.
Old 20 Nov 2012, 06:47 pm
Ray_Dockrey's Avatar
Default Re: Replaced Thermostat 06 PT Getting Engine Light ERROR P0128 Coolant Thermostat
Sounds like you got a bad thermostat. Seems like the fails ages in these cars don't work so well. I would get a normal thermostat and make sure you get the right temp thermostat.
p0128 - coolant thermostat.....how vague can you get it? srebik Tech & Performance Forum 2 02 Nov 2011 09:32 pm
need help with thermostat removal and coolant type timberghost159 Tech & Performance Forum 24 26 Jun 2010 08:19 am
Replaced thermostat, but engine temp says cold while driving... missingwhatsnear Tech & Performance Forum 5 11 Feb 2009 08:39 pm
Thermostat or Fan JazzeCouture General PT Cruiser Discussions 1 25 Jan 2009 09:05 am
Replaced Thermostat &Cap..... rockrtboy General PT Cruiser Discussions 7 29 Mar 2007 10:36 pm
