pt jerking
Like Tree2Likes
  • 1 Post By Busted_PT
  • 1 Post By jrbsr05pt
Old 20 Nov 2012, 06:22 pm
Default pt jerking
i have a 01 pt spec ed 5 speed it runs great then starts bucking and jerking when it shuts off u let it set a few it starts up and runs only to do the same thing agen had it scand said cam sen so replacd it also replaced fuel sender but still doing it any ideas
Old 20 Nov 2012, 06:42 pm
cruisin03pt's Avatar
Default Re: pt jerking
Hmm maybe a timing issue? It only takes one tooth on the cam gears to make her run funny, if not at all. I would start with one system at a time. Rule out the easiest first. Then work from there. My first guess would be to check fuel and electrical.
Old 20 Nov 2012, 08:34 pm
it runs perfect till it starts bucking
Old 20 Nov 2012, 09:40 pm
Wow, does it do it when you let the clutch out? Mine bucks in second gear when shes cold. I just keep the rpm's a little higher to fight it.
Old 20 Nov 2012, 09:46 pm
No when it does it it won rev in nut but I took the ecm out of my wife's and now hers won't turn over like the anti theft is activated
Old 20 Nov 2012, 10:03 pm
Check the wiring from the sensor to the main harness, check the crank harness as well. Can fall down and rub the axle and cause this problem.
UptownSport likes this.
Old 20 Nov 2012, 10:24 pm
jrbsr05pt's Avatar
if you didn't do this then this should solve your problem almost instantly. did you use a cam sensor from the dealership or from a parts store like advance, autozone or say o reillys? if its from a part store that may well be your problem.
cruserdad1976 likes this.
2005 n/a 5 speed. 177365 miles. spectre cold air intake, white and pink leds under dash and back seats, purple leds in vents, wall with 1 18" subwoofer built behind back seat(soon to be either 16 American bass vfl8's or 4 18's with the wall rebuilt all the way to behind the front seats,cant wait!!!), blue dash lights, pink turn signal indicators. 3D tails and tinted backup lights. Power antenna (that no longer has power ha!) another one gone but wont be forgotten
2003 gt turbo. 130245 miles. autostick, mopar riceplate, 3" o2 housing and downpipe. custom diablo tune (totaled, gone but not forgotten)
2003 dream cruiser. autostick, mopar body kit, mopar bov, cai. s1 injectors. mopar s1 pcm. 3" 02 housing and downpipe installed from last turbo, upper IC hardpipe more on its way soon.......... diablo tuner in the near future.
Old 21 Nov 2012, 12:23 am
cruserdad1976's Avatar
what jrbsr)5pt said then after marker sensors just dont get it on ht ePT the mopar ones are higher but they work
Old 21 Nov 2012, 06:05 pm
i fixed it it was crank sen thanks for the help
04 PT, jerking when accelerating solluna975 Tech & Performance Forum 9 08 Feb 2014 11:45 pm
Slight jerking Fenris Tech & Performance Forum 2 06 Oct 2012 10:43 am
My car started jerking! helene Tech & Performance Forum 14 30 Oct 2011 09:58 pm
04 GT missing and jerking, Po300 robbie109 General Turbo Discussions 13 19 Jun 2011 07:47 pm
04 turbo - jerking on acceleration bahamaman34 Tech & Performance Forum 2 03 Oct 2009 12:34 pm
