Fuel tank straps
Old 21 Nov 2012, 07:12 am
Default Fuel tank straps
Problems seem to come in bunches. This time I have a fuel tank strap that has rusted through and is dangling from the bottom of the car. I will see if I can find one locally. I had a quick look and it seems that the strap is bolted at one end and clips in at the other. Hopefully I can get my hands up in there to remove the old strap and get a new one in. Anyone have any tips. I did a search, but didn't find anything. On the bright side, this could explain why my fuel gauge stopped working.
Old 21 Nov 2012, 10:54 am
cruserdad1976's Avatar
Default Re: Fuel tank straps
if you un bolt the bolted end i think you can get to the oter end if not you may have to drop the tank and replace them
Old 21 Nov 2012, 06:52 pm
Well, unbolting was the easy part. Trying to remove the old straps from the other end was the problem. There is a little keyway that you turn the strap 90 degrees and just pull it out. This would be easy with the tank removed, but it is another story when you can only lower the tank a bit. It took a great deal of patience and a bit of adult language, I managed to get it done.
empty fuel tank, engine runs bad afterwards autoenting Tech & Performance Forum 17 03 Sep 2010 04:36 pm
Is it ok to add fuel injector cleaner to gas tank? Mary General Turbo Discussions 11 10 Aug 2010 09:05 am
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Fuel Tank Doors ?? Will an 03 fit my 06....?? outfit Exterior Accessories Forum 4 03 Oct 2008 04:48 pm
P0452 Fuel Tank Pressure Sensor Error Code dornstar Tech & Performance Forum 0 22 Aug 2007 12:08 am
