Name that hose... Please
Like Tree2Likes
  • 1 Post By rob342
  • 1 Post By CREWZIN
Old 24 Nov 2012, 10:44 am
Default Name that hose... Please
Got the proper T-stat o-ring installed and a new cooling fan on my 02 pt cruiser. I ingeniously however manage to break a plastic tube that I am having difficulty identifying. I spotted it in the attached pic and was wondering if anyone could Identify the hose in the upper edge of the screen? The one taped to the hose leaving the left of the image...
Much appreciation...
http://i845.photobucket.com/albums/a...5-16161724.jpg
Old 24 Nov 2012, 11:56 am
Default Re: Name that hose... Please
Looked at my car (2001 may be different from yours). If your talking about the vacuum line that is attached to the top of the throttle body (your picture isn't the best) it's a line that goes down to the Purge solenoid.
If you look at the front of your car in front of the radiator, you should have a white slip of paper that has the vacuum line diagram of the engine. Look at the throttle body and you can see the line coming off that which goes down to the purge solenoid.
Old 24 Nov 2012, 01:44 pm
NitroPT likes this.
Old 24 Nov 2012, 01:47 pm
Good answer there, Rob.
NitroPT likes this.
Old 24 Nov 2012, 07:46 pm
thanks. that's twice today (:
PCV HOSE HELP robocek Tech & Performance Forum 15 13 Jul 2017 03:37 pm
Where does this hose go? Fuct Tech & Performance Forum 7 09 Jul 2013 06:33 pm
PCV Emission Hose dayle777 Tech & Performance Forum 10 27 Aug 2011 08:21 pm
PT Hose Problem pug Tech & Performance Forum 1 06 May 2011 06:33 pm
Hose head BoyJusCruisin Tech & Performance Forum 2 30 May 2002 12:32 pm
