pt gt 5-speed manual trans axle seals
Like Tree2Likes
Old 25 Nov 2012, 03:01 pm
Default pt gt 5-speed manual trans axle seals
my transmission is leaking out of the passenger side axle.. looking for the seals and i cant find them anywhere.. does anybody know the part number
Old 25 Nov 2012, 05:06 pm
Default Re: pt gt 5-speed manual trans axle seals
I don't have an OEM part number but make sure you get it from the dealer, because any other auto part place will have a size a 1mm too big and will keep leaking....
Or you can get them online ( like I did ) by size : 34mm (Shaft) x 52mm (Bore) x 8mm (Width) ....make sure they are double lip
Old 25 Nov 2012, 05:09 pm
look up "differential seal"
i found them at vatozone easy enough. then again these fit my NA car. i didnt look your car up, you never mentioned a year
Old 25 Nov 2012, 07:33 pm
UptownSport's Avatar
It's a GT so it'd be the t-850, dunno if it's diff than the N/a trans seals
Old 25 Nov 2012, 08:45 pm
xwing777's Avatar
Its a getrag 288, not the neon's t-850 if it was factory.
XtrmDC2 likes this.
Old 25 Nov 2012, 09:11 pm
I believe that's a seal for an automatic, because the Timken 3459S measures 40mm x 58mm x 9mm
You need seals for the getrag 288
Old 25 Nov 2012, 09:14 pm
This is the seal I put on mine...
Metric Oil Shaft Seal 34 x 52 x 08 34x52x8 Double Lip | eBay
Old 25 Nov 2012, 10:56 pm
The OEM part number is 5083953AA
Old 26 Nov 2012, 12:11 am
Ooops- Yes- PT had Getrags
Old 28 Nov 2012, 11:15 am
yea its the getrag and i found out about getting them from a parts store.. they gave me the wrong one. but i called dealer and should be here tommorow.. thanks for your replies
XtrmDC2 likes this.
Manual trans Cruser need help!! jrod1295 Tech & Performance Forum 1 18 May 2012 11:48 pm
manual trans noise wyok General PT Cruiser Discussions 2 12 Oct 2010 05:28 pm
5 speed trans oil? Kjj Tech & Performance Forum 2 29 Sep 2010 03:55 am
FS-stage 1 for 03 manual trans nuptgt4me Classifieds: For Sale/Trade 5 22 Apr 2010 11:10 pm
New 08 manual trans question... pigmywolf Tech & Performance Forum 5 21 Sep 2009 08:10 pm
