Hello from Australia
My friends manual PT Cruiser 2001 PCM died and as Chrysler dealer no longer has replacements I managed to source a new one with details below. Will it work with a manual transmission ?It will be fitted and programmed at a Chrysler dealer.Thanks Stump P.S It only has 51,000Km on the clock. (31,690 miles) For Sale Chrysler Powertrain Control Module (PCM) for 2001 PT Cruiser with 2.0L and automatic transmission.. Part number: #5033206AD This module will need to be programmed by a Chrysler dealer ( software, VIN number, secret key data). |
Did you ask the dealer about any of this? If they tell you no. Right or wrong it's not going to matter. Try one of those refurbishing companies. Maybe they can help you.
i use the automatic computers in stick shift mustangs because they have more agressive spark and fuel curves, as well as no rev limiter. to make this work you have to rewire the neutral safety switch, or the car will not start when you turn the key.
i helped a friend swap a manual trans into a mazda RX-7. the only problem we had is after swapping the trans(using the automatic ECU), the car would not start. we had to re-connect the MLVS switch off the automatic trans and set it to neutral, and then it started fine. -you may have an issue because of this. additionally, your neutral safety switch may no longer function. one other thing i would be seriously concerned with is i believe someone said the automatic PT's only rev to 3,000 or so in neutral. your car may do this in any gear(but i don't know) if it were my car, i would NOT chance it. |
Thankyou for the feed back.The Dealer did say it should work.Using a automatic PCM on a manual car.He also said it would not work the other way round if it was a manual PCM put on a automatic car.I went ahead and bought the PCM for $300 and will give it a go.The Dealer originally told my friend the part was not available and the car is now a write off.
Thanks for the link and will give them a try if there are problems with the PCM. Cheers Stump |
Thread Tools | |
Display Modes | |
Transmission Control Module | BoneDaddyCruiser0808 | Tech & Performance Forum | 4 | 30 Jun 2013 05:22 pm |
Transmission Control Module | atlantaroger | Tech & Performance Forum | 5 | 02 Jun 2013 10:12 pm |
Where is the ignition (control) module? | bjagd02 | General PT Cruiser Discussions | 5 | 26 Feb 2011 05:21 pm |
transmission control module | gatorlake | Tech & Performance Forum | 1 | 22 May 2009 10:46 am |
Transmission Control Module | j1stahl | Tech & Performance Forum | 5 | 30 Apr 2004 08:57 pm |
