loud noise from front end...cooling fan?
Like Tree4Likes
  • 2 Post By 2step
  • 2 Post By quicksilverdon
Old 27 Nov 2012, 09:28 am
Default loud noise from front end...cooling fan?
Hey guys, upon start up my 05 N/A PT has a lot of noise coming from around the rad/fan, should the cooling fan start up upon initial start up in high speed? that is what i am guessing it is...could anyone be able to help me with this one?
Old 27 Nov 2012, 10:00 am
Default Re: loud noise from front end...cooling fan?
Describe the noise. Belts are the most common start up noise. I your defrost is on I believe it starts up as soon as you start the car.
Old 27 Nov 2012, 10:29 am
2step's Avatar
I had a loud noise up front. Upon a closer examination I found this.......
Old 27 Nov 2012, 12:08 pm
I believe if your A/C is on, engine fan will come on, and if you have setting on defrost, A/C will come on.
Turn fan speed knob to 0 and see if sound changes.
Also, if you stick your hand behind the shroud and your hand gets chopped up, the engine fan is on....
glendabarnes and zamfir2 like this.
Old 27 Nov 2012, 11:05 pm
i will take a closer listen tomorrow when i start it up again
P304 misfire and loud noise Spidey General PT Cruiser Discussions 16 09 Oct 2017 06:48 pm
loud ticking noise in my engine 96realwe Tech & Performance Forum 5 12 Feb 2011 08:41 pm
Wobble. Loud noise! What do i look for? matthewmilbut Wheels, Tires, Suspension 22 10 Feb 2011 01:37 pm
Loud noise repost! Please help matthewmilbut Tech & Performance Forum 0 07 Feb 2011 11:03 pm
Loud Ticking Noise (please help) alnewp Tech & Performance Forum 6 08 Mar 2009 07:41 am
