wallbro 255 and fuel return line install??
Old 28 Nov 2012, 11:41 am
Default wallbro 255 and fuel return line install??
i have a 2003 pt gt and im waanting to upgrade my fuel pump and install a return line.. has anbody done this.. just wondering what i will need.. im buying a kit off somebody with a srt-4. i have my stock pcm but i have a diablo tuner and aem wideband. anything else i need??
Old 28 Nov 2012, 01:57 pm
Default Re: wallbro 255 and fuel return line install??
the correct way to add a return line would be to bypass the built in pressure regulator and add an adjustable pressure regulator under the hood from a company like aeromotive.
i would keep in mind that when you start dealing with AN fittings and braided lines, your fuel system budget will quickly exceed $1000. i went this route on a mustang and after buying all the fittings, the braided lines, the fuel rails, the pump, and the regulator, the bill was ~$1700
if i were in your shoes, i would not go this route. i would just install the 255 pump the others here are using and call it a day.
Old 29 Nov 2012, 10:54 am
i bought the return line kit with fuel pressure reg and all the braided line and wallbro fuel pump for 300.. just need some an fittings
Old 29 Nov 2012, 10:56 am
u can buy new return line kit from modern performance for like 350
Old 29 Nov 2012, 11:02 am
Go to ptcrew.com and ask those guys...I know a few of those them running a return line
Old 29 Nov 2012, 11:14 am
thanks
Turbo oil return line leak littleblueGT General Turbo Discussions 7 24 Apr 2016 10:29 am
Fuel Line Leaks- Look at your PT UptownSport Tech & Performance Forum 14 22 Jun 2015 09:15 pm
fuel line question... vidkid Tech & Performance Forum 9 12 Oct 2014 03:12 pm
WTB: nylon fuel line dpmeeks Classifieds: Want To Buy 4 24 Sep 2011 07:14 pm
Impending turbo doom, or just a clogged oil return line causing whine and smoke? icezebra Turbo Performance 5 05 Oct 2008 04:14 am
