wont crank please help
Old 30 Nov 2012, 05:47 pm
Default wont crank please help
First to those who have been a huge help without even knowing it. Thank you for years of assistance. With that said, this is the first time ive needed to post before finding my answer. I am helping an ill neighbor with a 2001 non turbo pt cruiser, 135 k auto. 2 years ago the pt cruiser overheated, cracked the radiator, and was towed to a shop. The shop replaced the radiator and found an electrical problem to the fan. The mechanic with the answers got fired and the car was never fixed. The car was returned home and sat for 2 years. Here where I come in. My neighbor is very ill and cant pay her bills. I offered to get the car running and sold for her. Free of charge of course.
Heres where Im at now:
1. Replaced battery with known good battery
Dash powers up but will not crank. dash does not short from on to start position. nothing changes in start.
2. Checked all fuses and relays. swapped with know good from my 04 cruiser
still nothing
3. jumpered starter solenoid to battery. started up like new even with 2 yo gas
4. jumpered 87 to 30 on starter relay. started up like new
5. put meter on all battery cables for resistance and voltage. all good
I have no codes at all.
I have try to abuse the key switch and nothing changed.
I do not have inverted torx sockets but i guess my next part is key switch? Any suggestions?
Old 30 Nov 2012, 06:27 pm
Default Re: wont crank please help
well, if it started by jumping the solenoid, i would say put a new or rebuilt starter in. they don't just sell the solenoid. on my wife's 2001, we put a '94 jeep solenoid on the starter and it has worked flawlessly for over a year. don't remember the exact model so you're going to have to match up the jeep solenoid to the pt starter solenoid. should be able to with pictures.
2016 Kia Soul Plus Black
Old 30 Nov 2012, 07:02 pm
if the starter motor or solenoid was out, jumping 30 to 87 pin on starter relay would not help. also i have found a few others on this site with same two electrical problems but not answers. fan not functional with no crank from key. possible bad pcm?
Old 30 Nov 2012, 07:11 pm
Use a voltmeter on Pins 85 and 86 of the starter relay, and have someone turn the ignition to start and hold it. You should see +12 (or -12, if you have it backwards) on the voltmeter. If you are not seeing voltage, you either have a bad ignition switch that isn't passing "start" to the ECU, a bad ECU that isn't passing "start" to the relay, or a key/ECU mismatch. I think in the latter scenario you'd see the alarm warning on the display showing the immobilizer was triggered. It *could* also be a wiring issue, but if everything else on the car appears to work, that is likely not it.
Old 30 Nov 2012, 08:04 pm
still nothing
If you can cross it over that tells me the starter is good. The relay is not being energized. Could be the connector for the ingnition.
Old 30 Nov 2012, 09:35 pm
so the wife came home and we tried the starter relay w multimeter. signal to 85? (dark w flashlight will check again tomorrow) showed 18 mv to 32 mv so something is making a connection if even a bad one. pulled the cover from ignition switch. how do i test at the switch? possible broken wire?
Old 01 Dec 2012, 12:50 am
Could well be a broken ignition switch actuator pin (Dorman part number 924-704). Costs about $40 bucks to replace and takes about 15 minutes. You will need a "security" T10 Torx to remove a couple of the screws holding the unit in place. There are how to's on Youtube from Dorman that show you how to change it.
That was my problem, all the lights came on but turning the key all the way to where the engine should crank did nothing. If the pin is physically broken it cannot make the connection to allow the solenoid to engage and allow the engine to crank.
I had almost identical symptoms to you and that was the cause, a common fail point on PT's.
good luck
Old 01 Dec 2012, 09:10 am
Also while your in their, check the connector for any charing. May need to disconnect to inspect.
Old 01 Dec 2012, 04:10 pm
update:
1. today i retested the starter relay position in fuse box. no power to 85 or 86.
2. i swapped out the ignition switch with a known good one. no change. actuator pin in one piece.
3. checked all connectors. all good
4. battery tested the fan which has been inop while running. high and low come on fine. connector showing slight melting at ground pin but not enough to keep it from making connection
5. learned another diagnosis step as i reassembled key switch. if you roll the key to start with the wipers going, they stop. meaning the switch was good anyways
ive also noticed that the check engine light comes on for a few seconds then goes out when switched to on position. in my 04 cruiser it stays lit till started
so what am i down to? neutral switch , broken wire or pcm?
Old 01 Dec 2012, 04:34 pm
At the moment that's all I can think of too.
Crank Sensor ejstith General PT Cruiser Discussions 3 11 Nov 2010 02:41 pm
Won't crank sometimes! RodF763 Tech & Performance Forum 8 09 Sep 2010 12:31 pm
02 pt died and won't crank over ronwins3 Tech & Performance Forum 16 23 Dec 2009 06:25 am
Bell crank bf4cm28 Wheels, Tires, Suspension 3 22 Mar 2009 05:07 pm
Cold Crank, 2nd Try. zzzhuh Turbo Performance 10 11 Jun 2003 10:45 am
