temp guage
Old 02 Dec 2012, 02:48 pm
Default temp guage
Just replaced my cooling and it works as it should. My problem is that the temp gauge doesnt work now.The scanner says the temp is 260 degrees. replaced the temp sensor already but is still the same. Anyone have any ideas what to check next?
Old 02 Dec 2012, 03:37 pm
Badglas's Avatar
Default Re: temp guage
It sounds like the wire from the sensor is worn/burnt and making contact to ground, or it is an open circuit. Not sure which way Chrysler works. I think circuit to ground is hot, open circuit would show -40. If I'm wrong it is the opposite.
Check continuity between the PCM and the coolant sensor. Check both the reference and return circuit. If the wires are good, it could be a PCM problem.
Ron
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Keep your eye on your temp guage CREWZIN Tech & Performance Forum 26 13 Aug 2009 10:48 am
Boost Guage KC2IFR General Turbo Discussions 8 27 Jul 2009 07:50 pm
any temp guage for turbo unit to monitor cool down time mino Turbo Performance 0 09 Oct 2007 06:24 pm
temp guage cruiser12 Tech & Performance Forum 0 04 Nov 2004 03:43 pm
