starts and then dies on me
Like Tree2Likes
  • 1 Post By sanatanadharma
  • 1 Post By ptcruisersteve
Old 06 Dec 2012, 12:02 am
Default starts and then dies on me
I have a 2009 pt cruiser, with 58,000 miles on it, and the other day we were at the store and I cranked the car and it started then died, I tried it again, it started and then died, so I waited a few minutes, I started and stayed alive for the remainder of the time I was driving, with no issues, check engine lights or anything. Anybody have ideas what it could be?
Old 06 Dec 2012, 07:32 am
Default Re: starts and then dies on me
Might have a clogged/dirty/malfunctioning IAC (Idle Air Controller).
Old 06 Dec 2012, 10:36 am
cruserdad1976's Avatar
or just some car deamons that happened your way
Old 06 Dec 2012, 01:40 pm
Problem may be with SKIM (sentry key immobilizer module).
zamfir2 likes this.
Old 09 Sep 2014, 05:44 pm
I have been having the same problem all week.
My mechanic told me today that the problem is that the idle control motor is sticking and that the throttle body has a huge carbon buildup on it.
I had wondered if it had something to do with the gas I'm using, but he assured me that it doesn't.
Hope this helps
OrchidGirl
Old 09 Sep 2014, 07:42 pm
gas doesn't go anywhere near the throttle body. Injectors spray into the intake manifold very close to the head.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 09 Sep 2014, 08:46 pm
On my 2007 PT Cruiser I have been having this problem also. After doing research and with the help of several experts on this forum I feel that it is caused by the SKIM (sentry key immobilizer module) failing due to low voltage caused by bad grounds. I have scheduled this weekend to remove all the ground wires on the drivers side fender, clean and solder every single ground wire together and then solder it to a new connector to the fender. Does your headlight flicker? Sometimes with bad grounds other issues come up.
Old 17 May 2017, 02:57 pm
I know this is an older thread but did you get around to trying this and if so, did it work? I've got a 2006 non turbo giving me the exact same problem. It will start then die for as long as I'm willing to keep trying, no security light, no error codes.
Old 17 May 2017, 04:50 pm
When this happens to me on the 2007 Pt Cruiser I can get it to start by either taking off the ground battery cable and put it back on or getting a battery jump by another car. I usually just replace the battery and it fixes the problem but it can be caused by bad grounds or by other issues. On the 2006 & 2007 it seems that the battery is under more of a load and on my 2007 Pt Cruiser I have to replace it every 18 months or so.
mrwade01 likes this.
Stops dead, then starts again. Stenvik Tech & Performance Forum 30 21 Oct 2012 10:38 am
Starts and stops again? daggie Tech & Performance Forum 10 20 Oct 2012 08:33 am
CRD starts and stops richard162 Tech & Performance Forum 1 20 Nov 2011 11:24 am
PT starts bad ProDigit General PT Cruiser Discussions 5 03 Nov 2010 02:23 pm
The Pt starts hard LNBNDN General PT Cruiser Discussions 1 03 Jun 2010 08:14 am
