2001 timing 2.4 non turbo
Old 08 Dec 2012, 11:58 am
Default 2001 timing 2.4 non turbo
I'm working on my wife's car and cannot seem to keep the crankshaft timing mark lined up after releasing the tensioner. I take up the slack with the exhaust cam and the belt still draws up the crankshaft sprocket. I did this same job 4 years ago for her and do not remember it being this difficult. Can anyone offer suggestions/tips/tricks?
Thank you
Old 08 Dec 2012, 11:59 pm
Default Re: 2001 timing 2.4 non turbo
This is as close as I can seem to get it, however when I had it this close earlier in the week it idled a little rough yet while driving it was great.
Old 09 Dec 2012, 08:39 am
compdr59's Avatar
INSTALLATION - TIMING BELT
(1) Set crankshaft sprocket to TDC by aligning the sprocket with the arrow on the oil pump housing.
(2) Set camshafts timing marks so that the exhaust camshaft sprocket is a 1/2 notch below the intake camshaft sprocket.
CAUTION: Ensure that the arrows on both camshaft sprockets are facing up.
(3) Install timing belt. Starting at the crankshaft, go around the water pump sprocket, idler pulley, camshaft sprockets and then around the tensioner.
(4) Move the exhaust camshaft sprocket counterclockwise to align marks and take up belt slack.
Here is a tip that's too late for you (sorry). Mark the timing belt and sprockets and transfer the marks to the new belt. You can't miss on the installation of the new belt. Once installed, you should be able to place a straight edge across all 4 timing camshaft timing marks while at TDC to be 100% sure. It felt reassuring when the straight edge went right into the marks.
Original Owner 135k
Old 09 Dec 2012, 03:08 pm
When taking the exhaust down 1/2 a tooth is the belt on or off? Am I too hold tension on either cam while slipping belt onto tensioner? Will the tensioner take up the slack on its own as I am finding that the crankshaft will move?
Thank you by the way for responding, I really appreciate it.
Old 09 Dec 2012, 05:56 pm
Move the exhaust cam while the belt is off. Thread the belt on as recommended, keeping it as tight as you can. When you pull the pin or allen wrench or whatever you used to lock the tensioner, the exhaust cam should move instead of the crank. If it doesn't, you curse, take the belt off, and try again.
Old 09 Dec 2012, 09:56 pm
Thank you zamfir2,
I had to move onto another project before I went crazy messing with this today. I am back on it tonight, and I was wondering if all of the slack is taken out on the intake side by threading it as tight as I can will the action of the exhaust tightening on the intake cam not cause the crankshaft to be moved as well. I ask because that is what I am experiencing. Thanks again for helping.
2001 - '02 New timing belt tensioner pulley 1972cudaguy Classifieds: For Sale/Trade 5 05 Oct 2012 10:16 pm
timing belt '03 turbo RNE228 Tech & Performance Forum 5 24 Jan 2012 02:44 pm
2001 Pt timing belt replaced..now wont run right! keller Tech & Performance Forum 8 22 Feb 2010 04:33 pm
Timing belt in 2001 Rlundstrom Tech & Performance Forum 3 13 Nov 2009 01:54 pm
Timing Belt 2001 Limited 2.4L CharliePT Tech & Performance Forum 2 08 Mar 2009 10:26 pm
