2002 car will not crank
Old 08 Dec 2012, 06:31 pm
Default 2002 car will not crank
I bought this car off an auction and it did not have a transponder key I should have one in it and programed monday Is there a process to get it out of lockdown mode
the only thing it will do is
lights brakes hazards windows and odometer
Old 08 Dec 2012, 07:25 pm
Ray_Dockrey's Avatar
Default Re: 2002 car will not crank
You may have other issues. Normally if you don't have the right key it will start but then die. And the key will need to be programmed to the car by the dealer or a locksmith. Only time you can program a key yourself is if you have two programmed keys already.
tip for no fan w/ or wo/ no crank conditon destinbeachbum Tech & Performance Forum 4 07 Dec 2012 06:01 pm
Crank shaft removal 2002, 2.4 L TomPortua Tech & Performance Forum 2 14 Feb 2012 03:06 pm
What is a rear crank arm? fastone General PT Cruiser Discussions 4 07 Jul 2011 06:30 am
Won't crank sometimes! RodF763 Tech & Performance Forum 8 09 Sep 2010 12:31 pm
Crank Scraper LAF Turbo Performance 0 18 Jan 2004 06:29 pm
