Miles on a tank?
Old 11 Dec 2012, 06:37 pm
Darthmactis's Avatar
Default Miles on a tank?
I have a 02 cruiser, my first. Just for it a few days ago and was wanting to know how many mile on a tank of gas is normal? I filled it up when I got it. I drove 265 miles and the gas light came on is that normal?
Old 11 Dec 2012, 06:40 pm
Default Re: Miles on a tank?
I have an '06 Base with the 5-speed. I can get between 330-380 on a tank, depending on what kind of driving i'm doing.
Old 11 Dec 2012, 06:43 pm
Badglas's Avatar
In my experience that's not bad.
Ron
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 11 Dec 2012, 07:08 pm
I'm sorry forgot to mention I had a automatic.
Old 11 Dec 2012, 08:00 pm
2step's Avatar
It depends on how far you drain it down. When you get that first "ding" and the light, you should have about 3 gallons left to go. You can go a long way on 3 gallons. When the light starts flashing, you're down to your last gallon. I think that's true also of the '06 and newer or it should be.
Many owners like to fill up at 1/4 tank on the gauge because it's believed that helps keep the fuel pump from overheating and otherwise getting stressed.
Old 11 Dec 2012, 10:57 pm
I just figured with most sites saying that they get a average of 20 mpg that I would get more miles out of a tank.
Old 12 Dec 2012, 08:47 am
A lot depends on the pump shut-off, also. If you pump 'till you see gas in the filler neck, you can go further....
Old 12 Dec 2012, 09:00 am
PhxPT's Avatar
265 is close to the furthest I've gone on a tank. Check your tire pressures regularly. 3lbs under average on all four of mine gave me 180 miles to a tank, it was not fun having to fill up every four days.
Old 12 Dec 2012, 10:16 am
cruserdad1976's Avatar
really its not about a tank of gas its all about HOW MANY GALLONS IN THAT TANK
I get 21-23 mpg so with 10 gallons i can go 210 miles but with 15 galolons i can go 315
how empty to how full makes all the diffrence
265 Devided by 13 =20.38 mpg
Old 12 Dec 2012, 12:36 pm
300 is the most I have ever gotten, with very conservative freeway driving.
24mpg is where my auto/turbo lite tops out.
The gas tank.. ucantcme General PT Cruiser Discussions 47 22 Aug 2016 11:01 pm
cruiser acting up when 60 miles left in tank salespy General PT Cruiser Discussions 26 27 Apr 2012 09:47 pm
150 miles to a tank of gas? realityrunner Turbo Performance 13 28 Apr 2010 04:48 pm
Gas tank leak asaccoma General Turbo Discussions 7 26 Dec 2007 09:54 pm
Gas Tank BruisersCruiser General PT Cruiser Discussions 5 14 May 2004 04:42 pm
