Timing belt
Old 11 Dec 2012, 10:45 pm
Default Timing belt
We have replaced the timing belt on a 2006 2.4 engine and the marks look right and the idle is good and runs smooth in idle. Above 3000 rpm the motor starts surge and popping. We thought the timing might be off but the marks look good. We have also replaced plugs, wires, tensioner and idler and new water pump. Has anyone had a similar problem that they were able to correct.
Old 12 Dec 2012, 01:16 pm
Default Re: Timing belt
Is this under moderate throttle, light throttle, or heavy throttle? Or all throttle? Any codes/CEL? Have you double-checked the wires and plugs?
Old 12 Dec 2012, 01:20 pm
Ray_Dockrey's Avatar
Is this driving it down the road or it sitting and you are revving it up. They have a rev limiter built into them that won't allow over a certain rpm when in neutral or park.
well timing belt went.. twress Tech & Performance Forum 20 21 Jun 2012 06:51 am
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
