air bag light on
Old 12 Dec 2012, 03:03 pm
Default air bag light on
06 Cruiser crd ...Air bag light on constantly, had a diagnostic ,and tells me UPPER FRONT RIGHT SATELLITE ACELLORATOR SENSOR faulyt. OK, but anybody know where its located and what it looks like help!!!
Also flushing the cooling sys and putting Zerex Go51 Hoat in, do I need to BLEED the System ,if so where are the BLEEDERS, regards from a snowy UK
Old 12 Dec 2012, 03:51 pm
Default Re: air bag light on
Can't help with air bag light but if you do a search on "air bag" on this forum on Google you'll find plenty of informatin.
As far as bleeding, YES, you need to bleed the system almost everytime you deal with it.
Old 12 Dec 2012, 03:53 pm
I believe that refers the accelerometer in the b-pillar, as I think the main accelerometer is built into the controller. Do you have side airbags?
The bleeder is located on the thermostat housing - I think there is a tech article on this site that shows the location visually.
Edit: Or maybe it's in that previous post
Old 12 Dec 2012, 05:29 pm
Thanks Guys, the second pic from cruzin give me the exact location of the bleeder.From internet searching this accelerater satelite may be behind the drivers side head light,on the radiator carrier rail???, any more info, thanks
Old 12 Dec 2012, 06:15 pm
guys if the airbag light on and the horn doesn't work then its spring clock
i have this problem in my car
Old 12 Dec 2012, 06:20 pm
The front right satellite accelerator sensor is behind the lower grille on the radiator support. It's attached with 2 screws. Unless your car is a right hand drive, it will be on the passenger side, not the driver side.
-Chris
Old 12 Dec 2012, 07:29 pm
i believe it is in the B-Pillar as well.
Also bleed the system while the car is running. if you try to burp a PT it wont work and she'll overheat.
The bleeder is right below the housing under the radiator cap, may have a little rubber nub covering it but its a generic brake bleeder screw with a 3/8 head :-)
Kind of a pain to reach, a wrench wont get it due to the angle but a 1/2 socket drive will :-)
Old 13 Dec 2012, 01:02 am
The acceleration sensors are the impact sensors. There are two at the base of the radiator support (one left and one right), and there's one at the base of each B-pillar, if there's side airbags.
Front right sensor refers to the one at the base of the radiator support, not the one in the B-pillar.
-Chris
Old 13 Dec 2012, 08:54 am
don't forget to disconnect the battery and step on the brake before you mess with it!
Old 13 Dec 2012, 11:16 am
Well , what a great response,thanks to all the respondents. My cruiser is right hand drive,so the right front will be the passenger side,is that correct??.Could
ROB342 explain the reason for stamping on the brake please.
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Brake Light Condensation/Tail Light Replacement? NewPTCruiserInPA Tech & Performance Forum 3 23 Jul 2012 09:05 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
