car turn's off in middle of road help !!
  • 1 Post By pluminator
Old 12 Dec 2012, 05:39 pm
Default car turn's off in middle of road help !!
guys i have a problem with my car
first it wont turn on tell i turn it with anthor car battary to battary with cables
then this is new happend to me few hours
when i turn the car it turn off by it self in the middle of the road
thank god i didnt hit any one i changed the stick from D to N as fast i can
and called my friends so i turn my car again with cables
anyways any advices am crying over here
Old 12 Dec 2012, 06:19 pm
Default Re: car turn's off in middle of road help !!
Not a lot of info here but could be as simple as dirty connection, bad battery, or bad alternator. Hope this a help.
Old 12 Dec 2012, 06:28 pm
oh dude 60% alternator its so expensive
Old 12 Dec 2012, 07:26 pm
Clean your battery terminals.
Make sure they are on TIGHT!!! and when i say tight i mean almost at the point of stripping the bolts. I once had a neon that they werent on TIGHT TIGHT. well lets say it did the same thing, and also melted my posts terminals to the top of the batttery :/
Have your battery tested, its getting colder out so it may just be drained, most places will charge it for free.
Napa, autozone, advanced auto will test that and your alternator for free, plus charge the battery at no cost.
Check your fusable links and grounds coming off the battery, trace all the wires to the ground points and see if they are corroded etc.
Hope this helps
Matt42 likes this.
Old 12 Dec 2012, 09:25 pm
Matt42's Avatar
Hope this helps
What he said. Sounds like a corroded connection.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 13 Dec 2012, 03:23 am
i'v got the p0513 :\ this morning
Old 13 Dec 2012, 07:14 am
P0513 is an invalid SKIM key code. Do you have another security key to try and start the car with? This might also be an issue with the SKIM module in the steering column. A battery terminal 'reboot' might also straighten it out.
Old 13 Dec 2012, 11:57 am
Agreed, try disconnecting the battery for 10 minutes.
Also when its disconnected, turn the key to accessory, which will cause the vehicle to instantly drain any power that may be still inside the ECU.
After 10 reconnect the battery and try again.
The Skim also has its own fuse either in the main fuse pannel or in the larger one under the hood, check that as well, a $0.15c fuse can stop a car dead in its tracks :-)
Old 13 Dec 2012, 06:08 pm
WHEN the battery disconnected turn the key to accessory" what that mean ? i dont get it,
btw guys 2day i bought a new battery and the car starting fine but...
i did a little test
that i disconnect the + cable from the battery when the car is on
after a while if the car turned off then its a bad alternator
and yes the car after like 10 min's found it off
Old 13 Dec 2012, 06:30 pm
i did a little test
turning the key to accessory drains any excess power that is left in the system. Stepping on the brake pedal does the same thing. its to insure that EVERYTHING is flat dead on power, to insure a proper reset
And that doesnt always work.
Any car will die if you disconnect the battery. the alternator only take the power from the battery, circulates than recharges the battery, if it has a bad battery on it, it will not run very long, and it wont run long with no battery. Have the alternator tested at a shop.
Another good alternator tell tale sign is wait until dark. drive the car around a bit, then tap the brakes. if your headlights dim on a new battery. good sign that your alternator is toast :-)
Help with Middle pass side motor mount Leannaluv Tech & Performance Forum 15 08 Sep 2014 02:07 am
painting the middle indent line surfandskim92 The Detail Shop 8 10 Feb 2012 07:55 am
Middle TN Member TD2593 Welcome New PT Cruiser Members 17 17 Dec 2011 11:39 am
2005 Fan middle pin problem I_LIKE_my_PT Tech & Performance Forum 1 10 Aug 2011 08:14 pm
Middle mount passenger side questions Leannaluv Tech & Performance Forum 4 24 May 2011 10:24 pm
