no central locking, radio,interior lights.
Like Tree2Likes
  • 1 Post By Darkside7789
  • 1 Post By ricksatluz
Old 13 Dec 2012, 02:12 pm
Location: Warmsley Manor, Tunbridge Wells Kent England UK
Default no central locking, radio,interior lights.
Hi Having just replaced some aftermarket door mirrors on my 2000x pt cruiser with second hand originals, fitted the n/side one ok when i connected the multiplug on the o/side one it blew something i now have no interior lights, radio, or central locking!!!!. the message in the speedo says no fuse! also the engine management light has come on. I have tried all the fuses on both blocks with no blown fuses ???? any ideas ?? or suggestions for a pt mechanic near Tunbridge Wells Kent.
Old 13 Dec 2012, 02:24 pm
Default Re: no central locking, radio,interior lights.
I just ran into this problem this morning hooking up my new dvd in dash radio. Look in the fuse panel under the hood for a fuse labeled "IOD" and it should have a plastic black puller around it. It was designed to be pulled so the car's battery wouldn't drain when the car wasn't used for long period or something to that effect. You will have to pry the black plastic part away "I just broke the two tabs on the top, but I"m sure you can take it off without breaking it" and pull that fuse. Mine was sure enough blown even if it doesn't look blown try replacing it anyways with a 20 amp fuse (never go higher than fuse rating) Hope this helps!!!
CREWZIN likes this.
The LedGlow Cruiser]
[COLOR="Black"]-Soundstream vir 8300-NR touchsreen headunit
-6 skar vvx 12's (dual 4 ohm)
-12 cubic foot box tuned @ 32 hertz
-re audio mids and highs
-Dc audio 3.5k
-Mechman 240 amp alt
-Cadence 0 gauge all around
-Plasti dipped rims and bumpers
-"Blue" VVME HId low, 15k high beams.
-149 db @ 38 hertz (need to get re metered)
Old 13 Dec 2012, 07:35 pm
Thanks Darkside7789, would this make the management light stay on as well? i did pull that fuse and it looked ok but will try replacing it in the morning
Old 14 Dec 2012, 11:10 am
YEY!!!!! replaced fuse all restored thanks for the help
Old 01 Jan 2013, 06:09 am
I have pulled the fuse on my car to try and rid of the no fuse message... It's ok..
I have read elsewhere that it effects the radio, power / central locking, and a couple of other things... Is one of those the interior dome light?
My radio, power locks, headlights, dash lights all work. BUT my dome light has no bulb in too...
Can anyone help?
Old 01 Jan 2013, 06:19 am
Maybe the switch off or bad. Just a possibility.
Old 01 Jan 2013, 02:05 pm
Dome light controlled by fuse #13 (10 amp) in dash fuse box,
and Fuse #18 (20 amp) in PDC under hood.
These other functions would also be out if fuse is bad (SKIM, RKE, visor vanity-mirror lights, overhead console, power mirror switch lights, cargo lamp).
Can anyone help?
Old 02 Jan 2013, 09:21 am
I'll double check again under the hood and see what's what.
Cheers.
iod fine, no c locking, radio, interior lights, etc 3037 Tech & Performance Forum 4 16 Jul 2012 06:06 pm
Central Locking fastdel Tech & Performance Forum 1 16 Sep 2009 05:14 pm
central locking key AlexJB Sound and Security Forum 1 18 Jun 2008 08:47 pm
central locking AlexJB General PT Cruiser Discussions 10 05 Jun 2008 11:01 pm
