cam position sensor code
  • 1 Post By truk6enroute
Old 15 Dec 2012, 03:10 pm
Default cam position sensor code
on my 05 pt the eng started surging and then cut off and wont start i got a p340 code and have replaced the cam sensor with no results then the crank sensor with no results i have visually inspected the wires and dont see any bare or broken wires i have gotten this code before but i replaced the cam sensor and it ran fine but this time it will not start any help would be appreciated thanke
Erik
Old 15 Dec 2012, 03:32 pm
Default Re: cam position sensor code
Erik
Pull the cam sensor out and have some one turn it over to see if the cams are turning. If they are then maybe the magnet is bad.
Old 15 Dec 2012, 03:45 pm
the magnet being the new sensor? or a magnet on the cam itself?
Old 15 Dec 2012, 03:54 pm
The magnet under the cam sensor. Also pull the sensor and look at the magnet to see if it turns when someone else tries to start the car. If it doesn't turn, the timing belt could have broken.
If you had to replace it before, it means your probably NOT using a MOPAR sensors but some cheap imitation from a parts store. You should ONLY use genuine MOPAR electrical parts. More expensive but they work.
Old 15 Dec 2012, 08:09 pm
so if the magnet isnt turning then the cam is not conected to the crank by the timing belt ?
Busted_PT likes this.
Old 15 Dec 2012, 08:30 pm
If the magnet isn't turning when you try and start the car it means the timing belt is broken and not spinning the cams.
When looking at the magnet, it's connected to one end of the cam.
PO340 Error Code -Camshaft Position (CMP) Sensor Circuit LindaL Tech & Performance Forum 4 12 Jun 2012 10:12 am
crankshaft position sensor veses knock sensor BeagleDad Tech & Performance Forum 6 13 Feb 2012 06:10 pm
Code P0340 Cam Shaft Position Sensor A Dsmsta187 General PT Cruiser Discussions 6 13 Apr 2010 09:01 pm
Code P0340 Cam Shaft Position Sensor A Leroy Western PT Forum 4 02 Apr 2010 04:01 pm
Code 340 Camshaft Position Sensor kghaddon Tech & Performance Forum 5 08 Jun 2009 09:09 pm
