Intake bolt stripped
Old 15 Dec 2012, 07:31 pm
Unhappy Intake bolt stripped
Hi all,
I bought a '04 n/a auto, a few months ago. It was running a little rough at idle. Soooooo i bought new plugs and wires, went out to undue the intake, and to my suprise..........not.... two of the bolts just spin. Question, How do i get the undone ?
Thanks
Old 15 Dec 2012, 07:39 pm
Default Re: Intake bolt stripped
You can buy yourself some "Easy-out" bits. A tool box isn't complete without a set. Watch the video to see how it works.
Old 15 Dec 2012, 07:49 pm
try to get a pick or small flathead underneath the head of the bolt and pry up as you unscrew it. the bolts are threaded into little knurled brass retainers, my guess is those are just spinning in circles in the plastic. if that doesn't work and depending how loose they are in there, the intake might just pull off with a little persuasion.
let us know how it goes
Old 15 Dec 2012, 07:51 pm
rcktpwrd's Avatar
It's probably not the bolts that are stripped... In the lower half of the intake there are brass inserts that the bolts thread into, they are most likely spinning in the plastic. Someone in the past probably over tightened the bolts causing the inserts to break free if the plastic.
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS
www.rcktpwrd.com
Old 15 Dec 2012, 07:53 pm
rcktpwrd's Avatar
Once you get the manifold apart you can just use longer bolts and nuts that go completely through the manifold.
Joel
www.rcktpwrd.com
Old 15 Dec 2012, 08:17 pm
Originally Posted by lostinoregon View Post
Hi all,
Thanks
Sorry but, i need to split the upper intake from the lower.
Old 15 Dec 2012, 08:18 pm
we knew that once you said spark plugs. (:
re-read posts 3 and 4
Old 15 Dec 2012, 08:26 pm
Unhappy Re: Intake bolt stripped
Thanks rob342 I think the po did this as the head on one bolta is 10mm when the others are 8mm. Still, i see a lot of pry marks on this. i'll try to see what i can do.
Old 16 Dec 2012, 01:39 am
Check underneath for nuts - if the PO already wrecked the manifold perhaps he used a long 10mm bolt and a nut on the other side. The reason it's spinning is because nothing is holding the nut still.
Personally, I would hop on ebay or hit up a junkyard and get new manifolds. They are common and inexpensive. This would be an annoying problem to have repeatedly (for me).
Stripped thread Stempy Tech & Performance Forum 3 18 Nov 2012 01:05 pm
WTB - 06506379AA - Engine mount bolt (frame though bolt) wheelgarage Classifieds: Want To Buy 5 04 Dec 2011 10:31 pm
Which bolt is the tensioner bolt on the alternator? bjagd02 General PT Cruiser Discussions 6 23 May 2010 10:57 pm
STRIPPED SPARK PLUG HOLE chuck2112 Tech & Performance Forum 5 01 Mar 2010 09:52 pm
Stripped a thread while installing my starter RainyTX Tech & Performance Forum 1 08 Jan 2009 08:34 pm
