Oil Leak, Vacuum leak
Old 15 Dec 2012, 09:15 pm
Default Oil Leak, Vacuum leak
I had the head shaved and put new timing belt et al on my 2003 GT project car. After finally getting it running it had a slight oil leak that I could not identify. A local mechanic thought it was either the front crankcase seal or the oil filter adapter seal. Turns out it was neither. While driving I "punched it" to pass a car that pulled out in front me. When I got home there was oil dripping from the engine and the throttle response was weird. Turns out the PCV valve blew out of the valve cover. The hose was not very tight and as it turns out niether was the valve. I tightened the valve and put a new how with clamps on and it lools like the problem it solved. Now if I can just get the check engine light (vacuum leak and oxygen sensor) to go out it would be nice. Any common places for vacuum to leak?
Old 02 Jan 2013, 09:53 pm
Default Re: Oil Leak, Vacuum leak
PVC, EGR, Any and or all vaccume hoses, Vapor canister, Gas cap, uhhh intake manifold, spark plug grommets, valve cover gasket lol many things.
Tags
leak, oil, oxygen sensor, vacuum leak
vacuum leak clsals Tech & Performance Forum 11 21 Apr 2015 09:21 pm
Possibly a vacuum leak? sleepy General Turbo Discussions 6 10 Jul 2012 09:58 am
Vacuum Leak Solutions? code P1990 JulesPD General Turbo Discussions 1 16 Mar 2012 02:01 pm
Vacuum leak? Mulligandog Tech & Performance Forum 6 25 Feb 2011 09:00 am
Vacuum leak help discovering06 Tech & Performance Forum 11 14 Jan 2011 03:33 pm
