I NEED HELP! CAR WONT START!
Old 16 Dec 2012, 07:21 pm
Smile I NEED HELP! CAR WONT START!
I have a 2006 PT Cruiser, Touring Edition. Not a turbo. It is owned by one of those GPS "turn off" places till my last payment in September. I've had problems with the battery before, but we just put in a new battery now and the car wont start - not even clicking. We checked for the codes, but all it said was "done". I'm assuming, since the battery still works, that it's not the alternator. We've tapped the solenoid, and its still not coming on. I have no clue what to do, but we need to get this going. Any advice will help.
Thank you!!
Old 16 Dec 2012, 07:29 pm
Default Re: I NEED HELP! CAR WONT START!
does the starter work ?
Old 16 Dec 2012, 07:33 pm
It won't even click to turn over
Old 16 Dec 2012, 07:45 pm
There's been problems with the electrical parts of the ignition/key switch but first, call the GPS "turn off" place and see if they didn't accidently flip the switch.
ignition switch starting problems
possible ignition switch problem
2006 Ignition switch replacement
Ignition Switch Problem?
Old 16 Dec 2012, 07:58 pm
I'll have my husband check the ignition switch, but I've already cleared things with the GPS place, and it should be fine. It just beeps after we try to start it.
Old 17 Dec 2012, 01:15 pm
Have you tried jump-starting it? (Hooking another car battery to it)?
If it starts, see if lights are on - I'd bet your Multifunction switch went bad and lights stayed on - you have fog lights? They are usually the ones that stay on.
Old 17 Dec 2012, 01:22 pm
I know the power distribution changed for '06 - does it still have a starter relay?
If so, remove the relay, get a piece of stout wire, and WITH THE CAR IN THE RUN POSITION run the wire straight from the battery positive terminal to pin 87 of the relay. If the starter cranks you've probably either got a bad relay or a bad ignition switch. Swap the starter relay with one of the other relays there (like the horn) and try again with the key...
02 PT WONT START sgtwsky Tech & Performance Forum 2 15 Jan 2014 05:39 pm
02 wont start Sfos Tech & Performance Forum 15 10 Jan 2014 05:46 pm
04 pt wont start penstar66 General PT Cruiser Discussions 6 01 Sep 2010 02:27 am
Pt wont start chrisohan Tech & Performance Forum 19 10 Aug 2010 09:48 pm
Wont start now? morrisbeer General PT Cruiser Discussions 2 21 Feb 2009 10:14 pm
