Dead PT
  • 1 Post By CREWZIN
Old 18 Dec 2012, 05:59 pm
Default Dead PT
So pt drove great then I shut it off and started it 10min later it was throwing code p0300 and p2302 which I believe is normally means tune up I had to wait 3 days to get it home I went to go try and drive it home to work on it and it started and immediately died and now the code key trick wont work and it wont do anything all lights and acc work but starter dont even click any help would be helpful thanks
Old 18 Dec 2012, 06:50 pm
Default Re: Dead PT
P0300 Random Cylender Misfire Fault
Possible causes
- Faulty spark plug (s)
- Faulty ignition coil (s)
- Intake air leak
- Ignition coils harness is open or shorted
- Ignition coils poor electrical connection
- Clogged or faulty fuel injectors
- Injectors harness is open or shorted
- Injectors poor electrical connection
- Insufficient cylinders compression
- Incorrect fuel pressure
P2302- Ignition coil Failure.
So the 0300 and 2302 together give me a BIG feeling that your ignition coil is junk. Which would cause ALL the problems your having :-)
Also try to tap on your starter with a hammer. If the solenoid is shot it would give you starting issues but everything else would work.
Hope this helps
Old 18 Dec 2012, 06:51 pm
Default Re: Dead PT
It would be nice to know what year car you have. The electrical system had a big change in 2006 and many diagnostics may differ depending on the year of the car.
What about your battery? Is it new? Did you try a jump start from a good source? Have you checked the cables to make sure there's no corrosion that would stop your battery from transferring 12V to where it's needed.
Your two codes are completely different in nature so one might be an old code. What do you mean by the "code trick" won't work? Your not getting anything when trying? Unless the computer completely died, you have enough power for the lights so you should get something from the "key trick".
cruserdad1976 likes this.
Old 19 Dec 2012, 12:15 am
Default Re: Dead PT
Its an 05 the battery has plenty of power I tried to jump also just to make sure the part thats confusing. Me is the fact that the key trick to get the codes stopped working im thinking tgat the cpu went out but just dont know if there is anyway to know for sure
Old 19 Dec 2012, 11:20 pm
Default Re: Dead PT
Ok so the key trick not working was a bad fuse now car dont start at all and gives a p0522 oil pressure sensor voltage low
Old 19 Dec 2012, 11:31 pm
Default Re: Dead PT
I still say check the ignition coil. but thats my OP.
Old 20 Dec 2012, 10:33 am
Default Re: Dead PT
Can't be coil. Starter don't care if you got no fire. I will turn it over anyway. Op said starter dosen't do anything not even a click. Not to say there isn't secondary issues.The code on the other hand might keep it from starting if the computer is designed to protect the car in case of oil pressure loss. In that case could be a bad sender. These are famous for going bad.
dead car klondikeone Tech & Performance Forum 4 09 Nov 2010 02:02 am
PT Dead - Need Help! silver7 Tech & Performance Forum 14 08 Mar 2010 11:50 am
Pt dead Maineiac General PT Cruiser Discussions 5 21 Jul 2009 10:05 am
Dead, again renichms General PT Cruiser Discussions 6 03 Jul 2003 10:42 pm
