Car Dies when wipers/washers are used
Old 19 Dec 2012, 12:39 pm
Default Car Dies when wipers/washers are used
Hi-I have a 2003 2lt LTD Cruiser and it has covered 68K miles. I have had no problems until yesterday when travelling along, I used the front washers and all the dash lights went out and the car spluttered. I tried this again and the car stopped dead. No dash warning lights or anything. All the windows indicators etc. all still worked, but no dash warning lights. I have checked all the earths I can find, and now the problem is intermittant, but still when front or rear washers and / or wipers are used. It is as if the washers/wipers are shorting out the dash and ignition, but no fuses are blown................help please, with any ideas..........thank you.
Old 20 Dec 2012, 11:02 am
Default Re: Car Dies when wipers/washers are used
Take the plastic shroud off the steering column (2 screws, then snaps apart) - look at wiring on wiper switch and look at all the wiring in the column - something is shorting.
Old 16 Jan 2013, 05:01 pm
I have checked all of the Earths-all I could find, tested all the fuses, none were blown. Installed a new ignition switch. I have no indicators, dashboard lights, no ignition, no wipers, no door locks. No lights appear on the dashboard when turning the key, but there are live supplies to heater blower, headlights, windows. This is a strange fault, I have spent some time on it. Is there a main relay, that could cause this? Obviously I cant use the car as it does not start. I resent taking it to a dealer, as they just keep fitting new parts one by one until it works! Any help would be appreciated.
Pinny
Old 16 Jan 2013, 09:53 pm
My guess is a bad ground (earth). Check on the left inner fender under the air cleaner box behind the battery...you will find a number of wires grounded there all on the same lugs attached with just sheet metal screws...clean up these connections. btw...this is per my 08 but yours is perhaps similar.
Windsheild Washers CruzinGT General PT Cruiser Discussions 5 18 Aug 2010 03:16 pm
No turn signals, wipers, washers for 2006 pt thundert79 General PT Cruiser Discussions 4 13 Dec 2008 09:55 pm
Windshield Washers WAYNEF Exterior Accessories Forum 6 23 Sep 2004 06:11 pm
problem with led washers cheeseball Exterior Accessories Forum 0 23 Aug 2003 09:20 pm
LED washers ptcruz311 Exterior Accessories Forum 2 10 May 2003 03:57 am
