Cooling system problems
Old 21 Dec 2012, 01:19 pm
Default Cooling system problems
Hello,
I have an 02 touring, this summer I started having trouble with overheating. After driving longer than 30 min at 50+ mph or while sitting in traffic the temp gauge starts to climb quickly toward red. After doing some research here, I did the following.
Replace radiator fan and relays
Replace coolant temp sensor
Replace thermostat
Radiator flush and fill
none of these helped. It doesn't leak any where, and I don't know what else to try. I haven't been driving it, the possibility of being stranded with a ruined car is just not attractive.
Any advice would really help.
Old 21 Dec 2012, 01:24 pm
Default Re: Cooling system problems
If it's overheating while driving, good chance you have a cracked head gasket, slow leak into the combustion chamber where the coolant is burned off and out the back.
Time for a compression check.
Old 21 Dec 2012, 02:16 pm
Could also just be a clogged radiator!
Are you losing coolant, or no?
Old 21 Dec 2012, 02:19 pm
Have you read what he said about a "Radiator flush and fill" ????
Old 21 Dec 2012, 03:13 pm
Yes - but what does that have to do with a radiator being clogged or a system losing coolant?
Old 21 Dec 2012, 03:17 pm
Did you read he is not indicating losing any "coolant"?
Just because the parts were replaced does not mean that;.
1) they were all installed correctly
2) they are all functioning as they should be
The first thing we would perform in the shop is a cooling system inspection test and all appropriated pressure tests.
If failed or inconclusive:
Chemical test of the coolant.
Compression and or leak-down test of the engine.
Thermal check of the radiator and thermostat housing.
Electrical test of the radiator fans
If all else fails for the PT stop working on it and shop for a new Mares regulator!
Old 21 Dec 2012, 05:05 pm
Was that directed at me or someone else?
I did not read where he indicated no loss of coolant. I read he doesn't have leaks, but that doesn't rule out consumption. Perhaps I missed something.
Old 21 Dec 2012, 06:07 pm
How about checking to see if the fan actvates when engine is at temperature
Mine was doing the same until I found out fan was not turning on
03 gt atx mods are composite intake, big mouth bov lowered on drop zones with SRT-4 rims, full xenon urethane kit with 4" fog and 12000k hid, custome dual projectors, srt-4 front seats
Old 21 Dec 2012, 06:13 pm
He REPLACED the Radiator Fan and both relays. Yea, I know, still doesn't mean the fan is coming on but hopefully that was checked after everything was replaced.
Old 21 Dec 2012, 06:37 pm
This more or less rules out a fan problem. The fan should never come on while in motion - no fan is going to be more effective than moving through the air at 50mph. I just drove from Sacramento to Los Angeles without a radiator fan in the PT over Thanksgiving weekend!
The things that would cause an overheat while in motion is a clogged radiator, a wrecked pump, stuck thermostat, trapped air, headgasket failure, or bad cooling system pressure. In the case of the latter two, you would always have a consumption problem (coolant burned off, or escaping from somewhere).
Assuming there is no consumption problem, I would check the radiator with an infrared thermometer. I would check proper functioning of the thermostat by checking the temperature of the top radiator hose near the radiator. You should be able to check for coolant flow by removing the radiator cap and revving the engine - that *somewhat* rules out a pump whose impeller or pulley has separated from the shaft - but it could only be an "at speed" problem.
Overheating while in motion is very, very commonly a clogged radiator.
Bleeding air from cooling system bogaz Tech & Performance Forum 16 13 Apr 2016 06:44 pm
Cooling system noises BlueWoody Tech & Performance Forum 7 17 May 2012 08:18 pm
cooling system issue buztanut General PT Cruiser Discussions 2 23 Nov 2010 08:25 pm
cooling system problems BeagleDad Tech & Performance Forum 6 15 May 2010 03:58 am
cooling system ? cllwyrc Tech & Performance Forum 6 25 Apr 2010 10:35 pm
