P0456 and flashing CEL
Old 21 Dec 2012, 04:26 pm
PuterChickFL's Avatar
Default P0456 and flashing CEL
Hello all, today is the end of the world.......
Lately I've been throwing the above code when I crank up for the first time of the day. It will usually come on within the first 2 minutes while warming up. I will drive 100+ miles for the day and have no other issues. Also, sometimes I will sit in the car on a break, and I will turn the key on so I can roll down the windows and listen to radio and the CEL will flash sometimes. If I crank it it doesn't stay on.
What are some things I need to check?
Old 21 Dec 2012, 04:32 pm
Default Re: P0456 and flashing CEL
Some older posts:
OBD-II Trouble Code: P0456 Evaporative Emissions System - Small leak detected
P0456
2002 Pt error code P0456
Old 21 Dec 2012, 05:03 pm
Could be a bad gas cap. A leak with one of the vac lines. Check the big hoses first, these should be tight and no cracks. If you find any loose trim off a little off the end and re-install.
P0456 LooseJox Tech & Performance Forum 2 10 May 2012 08:55 pm
Engine Code P0456? AngelLover89 Tech & Performance Forum 1 10 Mar 2011 03:03 pm
Error code P0456 & 0340 RoadTramp113 Tech & Performance Forum 12 21 Feb 2011 08:29 pm
2002 Pt error code P0456 chellee Tech & Performance Forum 2 24 Jul 2008 07:56 am
code p0456 Punch General PT Cruiser Discussions 0 26 Aug 2003 02:10 pm
