2003 won't start after new plugs
Old 24 Dec 2012, 04:34 pm
Default 2003 won't start after new plugs
Hello,
My PT cruiser had code 0303 and engine light is on. I changed the plugs and wires, now it won't start at all. No codes showing. When I try to crank the engine, it clicks like a bad battery sound and won't start. The speedo gage and the rpm gage climb fast and return to zero when I do this. Any suggestions? Thanks
Old 24 Dec 2012, 04:42 pm
Default Re: 2003 won't start after new plugs
Have the auto parts store load test the battery.
Also, check the cables...clean and tight...no corrosion.
Old 24 Dec 2012, 04:51 pm
Thanks for your input. I will have the battery checked out but would all the interior electric work if it was no good? Radio and dash are normal.
I am so happy to have found this forum. Browsing through, I see all kinds of help which is a great thing. Thanks so much
Garry
Old 24 Dec 2012, 05:02 pm
Yes, you can have lights, radio, guages all working but when it comes to the starter, you need almost all the power the battery can put out. Everything else can run on a very weak battery.
Old 25 Dec 2012, 10:45 am
cruserdad1976's Avatar
that is a great idea but im thinking some thing else is at play here maybe you some how have a unhooked wire???
Old 27 Dec 2012, 10:05 am
If you're not turning the engine over, forget about codes....
Hook up another car with jumper cables and see...
2003 PT wont start.. vikz General PT Cruiser Discussions 1 04 Jan 2012 07:49 am
2003 pt won't start clsals Tech & Performance Forum 1 14 Jul 2011 08:57 am
Flushed car, checked plugs and wire, no start Dill Tech & Performance Forum 16 12 Jun 2011 10:20 pm
2003 Touring doesn't start TimothyG Tech & Performance Forum 3 11 Jan 2011 07:36 am
Rough Idle on 2003 Pt- Not plugs and wires Jungle Jim Tech & Performance Forum 6 27 Mar 2007 09:22 am
