No power to cooling fan
Old 26 Dec 2012, 10:39 pm
Default No power to cooling fan
Hello all. I'm a new member but have been referring to this site for a few months. I've been trying to solve my grandma's 2002 PT cruiser's overheating problem and I haven't been able to fix it. I can't get the cooling fan to come on. I took the fan out and tested it right off the battery and both high and low speeds work. I replaced the temp sensor, 40amp fuse and high, low relays. I've read some post about loose wires, I'm curious if that could be my problem. I checked out the connections under the battery box and fan, everything seems tight? The car isnt shifting to 2nd gear, which is a whole different problem lol, so I'm unable to have any diagnostic scan done. Ive read a lot of threads and it looks like this is a common problem discussed. I'm looking for some advice on where to go from here. Thanks guys, any advice would be appreciated.
Old 26 Dec 2012, 11:39 pm
Default Re: No power to cooling fan
If you have a multimeter, you can check the fuse and relay sockets for the correct voltage for both battery supply and the pulldown for the relay. With some spare wire, you can power the fan directly from the battery through the fuse and/or relay socket. That will help narrow down where the issue is.
One other thought: When I replaced the fan in my PT last month, the power connector was *full* of corrosion. Did you check to be sure yours is in good shape?
Old 12 Apr 2014, 12:13 am
Mine was bad relay sockets, wiggle the relay around, with the top off
finger pushing the relay found the problem Dirty contacts makes heat
eventually the socket gives up
2006 PT Cruiser no power to power seat paradyne64 General PT Cruiser Discussions 5 29 Dec 2016 02:54 am
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
FIXED: No power to power sockets, front or rear InTheBlack Tech & Performance Forum 2 11 Jan 2011 11:12 pm
A/C not cooling at all bigjoe1651 Tech & Performance Forum 5 10 Oct 2009 02:42 pm
