rev limiter coming in at 4000 rpm after jet chip installed
Old 26 Dec 2012, 11:58 pm
Default rev limiter coming in at 4000 rpm after jet chip installed
Hi, I have just installed a v-force jet chip into my 02 na cruiser and now i have a problem. After install every thing seemed fine, car started as it always did. I was letting it warm up as i cleaned up from the install and when i got into the car after letting it warm up the engine light was on. So i took it for a drive down the street and when i stepped on it, it was cutting out at about 4000 rpm. I am asumming it was hitting a rev limiter of some sort. Has anyone else come across this or does anyone have any ideas what it might be?
Old 27 Dec 2012, 12:04 am
Default Re: rev limiter coming in at 4000 rpm after jet chip installed
Most people here don't use the jet chip unless they are into snake oil. Have you done the 'key dance' yet to find out what error codes your PT is throwing??
To do the key dance, turn everything in the car off, no stereo, wipers, lights, etc., just to keep the system load down. Turn your key to the accessory position, that is two clicks prior to the start. So, you have Off, Acc, On, and Start (which is the spring-loaded position). Turn to Acc, wait a few seconds, then On, Acc, On, Acc, and On... leave it in the On position (NOT THE MOTOR START POSITION!), you should see a series of dashes ------ at your Odometer, while the PT runs the internal diagnostics testing. Takes maybe 10 to 15 seconds or so and then it will return the DTC's (diagnostic trouble codes).
You can come back here and post the codes, and/or go to the library link in my sig block and download the code definitions and look into them. Either way, you are most likely going to see some kind of code displayed.
Old 27 Dec 2012, 12:11 am
Thanks for the help i will do that! BTW what do you mean by snake oil?
Old 27 Dec 2012, 12:15 am
Well, trying not to be offensive or insulting, but the jet chip is a joke. There are three groups out there, in regards to the Jet Chip: (1) those who think it's the best danged thing since buttered toast, (2) those who don't care and don't give a hoot, and (3) those who don't believe in the hype and smelly BS that goes along with that carp, along with snake oil, p#nis enlargements, and other faux items....
Old 27 Dec 2012, 12:17 am
Cool Re: rev limiter coming in at 4000 rpm after jet chip installed
God bless the faux
Old 27 Dec 2012, 12:27 am
Yes, I tried to explain to my wife that my wreck wasn't real, that it was a phony faux pas...lmao....
Old 27 Dec 2012, 01:28 am
Ok i got the code. It is p0106. I seen it has something to do with the map. I did have to hook the v-force into the map so maybe i didnt get a good conection. I'll have to check in the morning its to dark and wet out to do so now. Thanks for the help i will let you know how it goes in the morning.
Old 27 Dec 2012, 03:22 am
Chrysler Code P0106
Map sensor as you said.
Your internet chip has screwed with your PCM. Remove it, disconnect the Neg battery cable, wait 20 minutes and reconnect to reset the PCM. Dont re install bargain technojunk :-) if it cost under $900 its not a performance chip and it should never be introduced to the PCM *no offense* :-)
Causes:
- Manifold Absolute Pressure harness is open or shorted
- Manifold Absolute Pressure sensor poor electrical circuit connector
- Faulty Manifold Absolute Pressure sensor
- Faulty Powertrain Control Module (PCM)
Old 27 Dec 2012, 09:51 am
Exclamation Re: rev limiter coming in at 4000 rpm after jet chip installed
I have a diablo trinity that works well, I have no pics though
Old 27 Dec 2012, 10:07 am
Sorry that last one didn't work for ya.
Ah Chrome you left the door wide open. But you are dead right on this one. Is this a kinder gentler Chromenut I'm seeing here?
Grinding/rotating noise coming from left side of car when coming to a stop...help? quietcharm23 Wheels, Tires, Suspension 3 10 Apr 2011 08:43 pm
Has anyone installed a Jet Chip 90417S in a pt gt Chasmopar Turbo Performance 9 31 Oct 2010 06:27 pm
Engine reving at 4000 rpm Dunkinder Tech & Performance Forum 3 17 May 2010 03:26 pm
Best chip for PT 2004 Auto Jet Performance chip or Stage 1? ROCKETMAN8060 Tech & Performance Forum 2 05 Feb 2010 04:22 pm
REV LIMITER?? blue06 Tech & Performance Forum 7 29 Jun 2008 08:55 pm
