Indicator/Wiper/Headlight not working
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By arorag
Old 28 Dec 2012, 03:38 pm
Default Indicator/Wiper/Headlight not working
Hi,
I have a 2006 PT cruiser and its the 2nd time in 30 days this has happened. The wipers/indicators/headlights have stopped working. 1st time when this happened, the mechanic replaced the whole fusebox and it started working fine (this was an expensive affair), now within 10 days once again the same thing has happened. Wipers/indicators aren't functioning. Not sure what is causing it and how it can be fixed? Please suggest...
Old 28 Dec 2012, 04:09 pm
Default Re: Indicator/Wiper/Headlight not working
Might be the multifunction switch on the steering column that controls all those things that aren't working.
pluminator likes this.
Old 31 Dec 2012, 09:36 am
Thanks for replying...
Switch seems to be fine coz every-time the mechanic changed the fuse-box, everything started working fine - have tried that twice so far...
Old 31 Dec 2012, 01:13 pm
Check the multifunction switch relay, sometimes they take a bathroom break for no reason
Old 31 Dec 2012, 02:58 pm
You have a short somewhere. Most likely in the switch. Would have to be tested out with a meter to know for sure. The other option would be the connector in the column. Look for melting. Let us know what you find.
Old 31 Jan 2013, 02:55 pm
It was the switch, we are going to be replacing that now... lets see, hope that solves the problem for good!
Oil pressure indicator muttonjavelin General Turbo Discussions 6 08 Aug 2012 04:06 pm
Shift Indicator GinPa General PT Cruiser Discussions 9 29 Nov 2011 05:34 pm
L. Headlight low beam not working ProDigit General PT Cruiser Discussions 2 11 Nov 2010 12:27 am
One headlight not working 06girl General PT Cruiser Discussions 4 10 Sep 2010 07:54 pm
Cruise Indicator Light? PT_or_not_PT General PT Cruiser Discussions 1 12 Apr 2010 08:58 pm
