error code P0304...it was the coil pack
  • 1 Post By Busted_PT
Old 31 Dec 2012, 02:02 pm
Wink error code P0304..CORRECTION: IT"S NOT THE COIL PACK
CORRECTION: IT"S NOT THE COIL PACK... '03 GT. 105k miles. Went to pass a truck on the hwy and engine sputtered. 10 seconds later engine light came on. code P0304 cylinder #4 misfire. I understand cyl #1 and #4 share a coil however only #4 was not firing. Swapped around plugs and wires but no change. hooked up timing light and #1, 2 and 3 had a rapid pulse but #4 seemed to flash at half speed, I'm guessing somehow it was firing on the exhaust stroke only. If nothing else that narrowed it down to ignition and not fuel or vacuum problem. Figured I'd have to start throwing parts at the car and started with the coil pack...lucked out, might start out the new year on a good note afterall. Only problem seems to be the idle is slightly high, I'll try unhooking the battery to let the computer re-learn. maybe driving with 1 cylinder running so rich changed the programming
Old 31 Dec 2012, 02:46 pm
Default Re: error code P0304...it was the coil pack
I would check the vac lines. May hay disturbed one while working. or you may need to clean the AIC valve. May need to lube the pivot points on the throttle body. Check the cables if you had the upper intake off.
Old 31 Dec 2012, 05:44 pm
I did hand check the vacuum lines but maybe i'll try spraying a little starter fluid around see what happens. I was able to work around the intake though they made it as hard to get to as possible and I did hyperextend the throttle to get to bolts so thats a distinct possibility too. Not familiar with the AIC valve but I'll do a little research. Thanks for your thoughts, I'll get on it tomorrow.
Old 31 Dec 2012, 05:51 pm
You may have changed out a working coil by your description of the problem. The PT ignition system is a waste spark system so if you indicated a constant pulse on all 4 terminals then the coil was functioning as it should. Generally if the coil was faulty you would be getting no pulse or intermittent pulse on one or more terminals and not in specifically on the compression stroke or exhaust stroke by itself .
Old 31 Dec 2012, 06:38 pm
Lynn,
I'm thinking you were blinded by the flash of my signature pics and missed this.
UptownSport likes this.
Old 31 Dec 2012, 08:13 pm
Originally Posted by Busted_PT View Post
Lynn,
No I did not miss anything, the OP in the first post said a constant pulse on all 4 but seemed only half on one terminal.That does not mean an erratic or absent pulse but constant. Technically that is not possible given the design of the Transformer style coil pack?
You may also read my very short description of a waste spark system and see that what he says can't fundamentally occur?
I would say if he gave that coil to anyone and even re-installed it on his PT it would probably not be bad.
uptownsport gave a like thinking I was caught me off my game...
Go back and re-read the OPs first post and you will understand the confusion he creates by his unusual method of testing a coil.
Old 31 Dec 2012, 09:47 pm
I thought he liked my humor.
Question Lynn,
Dose the ford 3.0 use that type of coil? Reason I ask, had a leg go on on recently.
Old 01 Jan 2013, 12:38 am
Typically most all coils can be used on most any ignition systems but the coil on PT and aftermarket replacements are Chrysler applicated. Ford uses a different coil package.
On a four terminal coil generally there are usually 2 coils and if a problem comes up it will usually be on one coil and the terminals seizing to function
None oil cooled coils seldom have intermiting operation. They either work or don't work. Ther are some exceptions such as damage to the coil.
Old 01 Jan 2013, 12:48 am
Ya this one started to miss under a load and got worse until one leg died all together. Thanks Lynn.
Hey I've known you sense last year !
Old 02 Jan 2013, 11:16 pm
You're correct..the new coil fix didn't last more than maybe 10 miles. I'm reading posts from 2008 and no one seems to have resolved this. My new codes are P0300 random miss, p2305 ignition coil B secondary circuit, and P0440 evap system Which usually accompanys P0441 evap incorrect purge flow but somehow is omitted in this new list, I have to reset the last 2 pretty regularly but they never seemed to affect performance, I may have to hand this to my dealer, this is gonna hurt.
Error Code P0304 Cylinder 4 Misfire Detected WV05Cruiser Tech & Performance Forum 16 23 Feb 2016 10:33 am
Question about coil pack muzicmax General Turbo Discussions 7 15 Oct 2012 07:12 pm
Error code P0300 & P0304 Jimpote03 Tech & Performance Forum 1 07 Mar 2011 05:28 pm
Error Code P0304 Max Tech & Performance Forum 2 30 Mar 2009 03:46 pm
