2006 Cruiser died randomly.
Old 01 Jan 2013, 04:06 pm
Default 2006 Cruiser died randomly.
My wife was driving her cruiser the other day, when the check engine light came on and then the vehicle died. I ran a scan and came back w codes p0340 and p0335. Changed both sensors with no problems, and decided to give it a plug change while I was in the engine anyway(it was about due). cleared the codes and tried again. now it is throwing the first two codes, plus P2302. the previous owner(we've owned it about 2 weeks) had the timing belt changed not long ago, and I"m wondering if he could have botched the job. Any ideas, insight, input would be greatly appreciated.
Old 01 Jan 2013, 04:28 pm
Default Re: 2006 Cruiser died randomly.
After you cleared the codes, changed the sensors and plugs did the car ever start again after it originally died? If not, check to see if the timing belt is still working properly.
Old 01 Jan 2013, 04:32 pm
Car hasn't run since. cracked the timing belt cover and the belt turns when the motor is cranked. if that's what you mean by working properly, then yes.
Old 01 Jan 2013, 04:37 pm
The other thing is, did you use auto store sensors as a replacement or use Chrylser/MOPAR parts. After market sensor make look like the same but it's been proven on this forum and others that they don't last very long ...or work at all. Inferior internal parts don't hold up.
Old 01 Jan 2013, 04:39 pm
this could very well be the issue. the wife went to autozone.
Old 01 Jan 2013, 04:46 pm
The problem is to identify which, if either, is a bad one. Never seen both sensors throw a code unless the timing belt goes. Usually it's the P0340 (Camshaft sensor) and we have seen a number of times where the harness to that exact sensor rub against things along the way to the computer so you might what to check the harness for worn spots.
Old 01 Jan 2013, 04:48 pm
that was my next step. I"m hoping the belt hasn't jumped any teeth as well.
PT Cruiser died no fuel and won't crank! PurpleCruizerConvertible Tech & Performance Forum 11 22 Nov 2012 11:17 am
2002 PT Cruiser died--Help! ikagram Midwest PT Forum 0 26 Aug 2012 05:02 pm
Cruiser Died MomsCruser Tech & Performance Forum 15 13 Feb 2011 12:46 am
2006 n/a died at redlight ChefTank Tech & Performance Forum 5 16 Jun 2010 05:48 am
My Cruiser just died HELP sfctgshort Tech & Performance Forum 6 19 Aug 2005 07:30 am
