2004 Oil Pressure Light
Old 02 Jan 2013, 07:48 am
Default 2004 Oil Pressure Light
Hello:
I have a 2004 turbo PT and the Oil Pressure Light is coming on when my speed is under 30-40 MPH.
If I speed up and accelerate the light goes away, but when I am coming to a stop and the speed is under 30-40 the light comes on and 'Dings'.
When I speed up, it goes out.
I do not seem to be losing oil as I check it. Overtime I do have some small spots on the driveway, but nothing in mass or unusal.
Is there an easy way to find out if it's the sensor or the oil pump or any other issues?
Does autozone do any free tests??
Thank you
Old 02 Jan 2013, 08:09 am
cruserdad1976's Avatar
Default Re: 2004 Oil Pressure Light
well since its a pt and they are known to fail id change it out and see how things go from theres
id say its a 95% chance its the sensor
Old 02 Jan 2013, 11:24 am
I agree with cruisedad all the way!
Old 02 Jan 2013, 11:37 am
Approximately how much does this cost if it is the sensor and a mechanic does it?
Is this a defect that I should I take it to the dealership?
Old 02 Jan 2013, 11:49 am
the sensor is under $50 its not super easy but it is for sure a do it yourself if you are so inclined if not id think a hour of shop time plus parts maybe $120???
Old 02 Jan 2013, 12:27 pm
Check the parts store I thought these were under $20. On this part OEM is not a must. IMHO I you can't do it.check around to see who is recommended. Dealer will be most likely more expensive. A call to all will tell.
Old 04 Jan 2013, 04:12 am
ukbeachbum's Avatar
I had this happen a few months ago and got the local garage to change the sensor, which I had sourced. Fixed the problem, but mechanic said it was a PITA. Glad I paid the hour's worth of labor.
2000 PT Cruiser Ltd Edition, blacker than black, Auto, 2.0L
Fixed: Cloudy headlights, Rear Defogger, Rear Wiper Motor, Multifunction Switch, Clunking noise up front......
BUT-Odometer not recording every mile-Turn signal warning chime always chimes-Temperature light always on...
...Still love the damn thing
Oil Pressure Light? thetunesguy General PT Cruiser Discussions 26 27 Oct 2016 06:37 am
oil pressure light issue Johns03PT General PT Cruiser Discussions 8 01 Apr 2012 08:34 am
Oil Pressure Light on bassahaulic52 Tech & Performance Forum 4 17 Nov 2011 09:08 pm
oil pressure light sticks on nomad327 Tech & Performance Forum 2 22 Nov 2010 06:54 am
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
