wierd problem?
Old 02 Jan 2013, 09:59 pm
Default wierd problem?
Hey guys i have a little prob here bought my pt with 136k on it,and its a 2005 when ever i pull a u turn on my street i pull in a driveway put it in reverse and my car dies b4 i can give her some juice.now ive just replaced the altenator and alt wires but it is a cold start when i do im kinda thinking maybe the fuel pump or carb could be causing it but not sure any help would be appreciated
Regards snorky
Old 02 Jan 2013, 10:04 pm
Default Re: wierd problem?
Regards snorky
The PT does not have a carb. If the fuel pump was dying it would just be dead so thats good news.
There are many things that can cause this, when a car is put in reverse it is put under slightly more load than it is in drive.
Start with power options, battery , terminals, connections, and grounds.
If those are all good check the camshaft sensor, idle air control valve, all vaccume lines, fuel injectors, EGR valve. for dirt, craked or worn bits etc
IS your engine showing a check engine light?
Old 04 Jan 2013, 01:12 am
lol shows you how much ik but no lights are on and everything elec is good just replaced the alt and battery last mounth.I thought it could be the IAC but havent had time to check evrything else
Old 04 Jan 2013, 05:09 am
well the IAC is a very likely cause, especially if it only does it in reverse, my car used to sputter down when i put it in reverse all the time, never died, but came pretty close. Cleaned the IAC and the problem went away :-)
Wierd Odometer Reading Copterdoc General PT Cruiser Discussions 6 19 Apr 2011 07:58 am
2001 Limited 198,740 Miles - WIERD Overheat... pasikobri General PT Cruiser Discussions 10 17 Mar 2011 08:12 pm
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
Wierd issue with engine not starting wedge22 Tech & Performance Forum 6 12 Aug 2010 02:57 pm
Wierd Horn Problem digitalpinscruiser Tech & Performance Forum 3 07 Jun 2008 06:23 am
