Wont start after catalylic converter replacement
Old 04 Jan 2013, 08:49 pm
Default Wont start after catalylic converter replacement
I have a 2004 with 186k on it, non turbo, 5-speed. I replaced the catalytic converter with a MagnaFlow CA complaint one and now the car wont start. I'm not getting any codes or CEL however I had to pull the battery to charge it prior to attempting to start the car today.
Prior to parking the car two months ago I had a P0138, the car had no power and progressively got worse as it was driven/cat warmed up... but had no problems starting.
Currently, the engine cranks over fine but wont start. Looking for advice on things to check next. All hoses and lines and attached, O2 sensors plugged in...
Old 03 May 2013, 09:37 pm
Default Re: Wont start after catalylic converter replacement
doe sit just crank over? or try to start?.
Old 04 May 2013, 12:59 am
The CAT has nothing to do with it not starting so check that off the list of suspects.
Old 04 May 2013, 06:48 am
Not all people are aware you are supposed to ground to the exhaust and not the body when welding exhaust. With all the iffy ground wires on these cars I could see that easily frying something.
just like any other car.. check for fuel and spark. listen for the fuelpump, try some starting fluid, etc.
pt wont start gee77060 Tech & Performance Forum 13 13 Nov 2014 09:14 am
I NEED HELP! CAR WONT START! AshHow Tech & Performance Forum 6 17 Dec 2012 01:22 pm
02 wont start anthonye559 Tech & Performance Forum 5 20 Sep 2011 11:44 pm
04 pt wont start penstar66 General PT Cruiser Discussions 6 01 Sep 2010 02:27 am
Wont start now? morrisbeer General PT Cruiser Discussions 2 21 Feb 2009 10:14 pm
