HELP
Like Tree2Likes
Old 05 Jan 2013, 12:01 pm
Default HELP
i have a 06 pt cruiser had starting problems with the cold weather had to jump start every couple of days bought a new battery still wont start turns over but not starting any ideas
Old 05 Jan 2013, 12:29 pm
Default Re: HELP
Is it turning over quickly with the new battery? If not, you cables might be at fault. Check all the ends of all the cables for corrosion.
mityqwik likes this.
Old 05 Jan 2013, 12:41 pm
Default Re: HELP
its turning over quickly i have cleaned the cable ends i am not good with cars
Old 05 Jan 2013, 12:51 pm
Default Re: HELP
How's your plugs and wires. If they're worn, it'll take a lot longer to start than usual.
Old 05 Jan 2013, 12:54 pm
Default Re: HELP
wouldnt start this past tuesday jump started it worked Wednesday jump start did not work took the battery to auto place dead battery bought a new one and still wont start
Old 05 Jan 2013, 12:56 pm
Default Re: HELP
Your post refers to cold weather starts, this would be more then likely a fuel delivery question.
Old 05 Jan 2013, 01:08 pm
Default Re: HELP
thanks i am not ruling anything out
Old 05 Jan 2013, 01:09 pm
Default Re: HELP
could it be a fuse?
Default Re: HELP
could it be a fuse?
Old 05 Jan 2013, 01:21 pm
Default Re: HELP
Its not a fuse
