replament engine
Old 05 Jan 2013, 12:08 pm
Default replament engine
Is the neon engine a direct replacement for the PT
2001 PT Limited 197,000mi. bone stock for now!
Federal Signal LED warning lights for fire dept. use.
Old 05 Jan 2013, 12:29 pm
Default Re: replament engine
No. A number of things are different.
Old 05 Jan 2013, 01:37 pm
Ok, thanks
Old 05 Jan 2013, 10:29 pm
UptownSport's Avatar
Neon had 2.0, and (US) PT's had 2.4's, except SOME turbo Neons, but '01 PT isn't a turbo
Old 06 Jan 2013, 12:49 am
Any other model have the right engine?
Old 06 Jan 2013, 03:09 am
Look thru links in my sig- there's a document somewhere on rebuilding the 2.4-
It talks of different brackets, mount tabs, oil filter positions, etc for each model.
Basic BOTTOM END is same for you back to 1994 in Stratus, pistons might be a bit diff but don't think it'd matter.
When oil filter is where axle would be, however ...
Old 06 Jan 2013, 01:12 pm
TurboDucky's Avatar
'01 / '02 - 4 door Stratus and Sebring cars use the exact same 2.4 engine. You'd need to swap out the oil pan, oil pump and all the brackets, but the basic engine is the same.
-Gary-
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 07 Jan 2013, 01:50 pm
-Gary-
No they don't, they're different. The Stratus engine has a bore x stroke of 86.5 x 100.0, and a compression ratio of 9.0:1. The PT engine has a bore x stroke 87.5 x 101.0 and a compression ratio of 9.4:1.
They're small differences, sure, but they are not the same engine. Just like the Caliber, Avenger, Patriot, Compass 2.4 is not the same as the PT 2.4.
-Chris
Old 07 Jan 2013, 08:42 pm
No, the same. ALL Mopar 2.2, 2.5, 2.0 an 2.4's have had a 87.5 bore since 1981
If there's some different spec, then it's another manufacturer
Old 07 Jan 2013, 09:37 pm
TurboDucky's Avatar
You may be referring to the 2 door cars. They are built on the Mitsubishi platform, and are not the same engines. The 4-door cars are exactly the same. The Caliber, etc use the new 2.4 "world" engine which is also different.
The original designed 2.4 remained in production until the PT was killed off. '01 / '02 were the same, '03 up use a different (32 tooth) tone ring, as well as a few other differences that make them non-interchangeable, but still the same bore / stroke / design.
Tags
engine, motor
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Pt Crusier engine change with a neon engine? reepos1 Tech & Performance Forum 2 09 Nov 2010 11:21 pm
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
Engine lurcing + engine lite come up on 05 GT Roadmaster General Turbo Discussions 11 18 Apr 2009 01:10 am
N/A Base Engine vs Turbo Engine Kirby General Turbo Discussions 7 02 Oct 2003 01:42 am
