replacement shocks and struts?
Old 05 Jan 2013, 04:32 pm
Default replacement shocks and struts?
What does everyone recommend? Wife's car has about 90k miles on it and the tires are wearing like it needs new ones. I called Napa and its about $130 fora set of 4. Any other suggestions?
Old 05 Jan 2013, 05:48 pm
PTJunkie's Avatar
Default Re: replacement shocks and struts?
That sounds about right, no need to go crazy expensive on a stock setup.
William____
2004 Bright Silver PT Cruiser Turbo GT H.O
Old 05 Jan 2013, 06:03 pm
Didn't plan on going crazy, just wasn't sure if there were better OE replacement options out there
Old 05 Jan 2013, 06:38 pm
The only thing is that wont help your problem. Unless you have scalping on the tire. You should look at the control arm bushing, ball joints and tie rods. If all is well there then wheel alignment.
Old 05 Jan 2013, 07:10 pm
Its the very outside corner of the tires being worn more than the rest.
Old 05 Jan 2013, 07:15 pm
sounds like tie rods to me.
Old 06 Jan 2013, 12:09 am
...interesting, ill check them out
Old 06 Jan 2013, 07:39 am
compdr59's Avatar
At 90k it may be time for a complete front end refresh.
Original Owner 135k
Old 11 Feb 2013, 08:50 pm
Just got brand new Michelin Destinys for the PT Cruiser. I love these things. Im going to take the car to the shop tomorrow to work on it a bit. Any real way to tell if the tie rods, ball joints and control arms are worn out?
Old 11 Feb 2013, 10:30 pm
yep :-D
Tie rods are easy. lift the car, then rock the wheels in and out while holding each side. If they move. tie rods are worn.
Control arms are easy, look at the bushings, if they look cracked or torn, or the arm itself looks warped replace em.
Ball joints usually will make a popping noise while driving, also you can check them visually to see if they are torn :-)
SHOCKS AND STRUTS the_fatman Wheels, Tires, Suspension 23 20 Jun 2012 10:31 pm
Replacement Struts and Shocks sscanlan Wheels, Tires, Suspension 1 13 Feb 2011 03:58 pm
What struts/shocks to buy? Samson Tech & Performance Forum 3 29 Sep 2010 03:26 am
wtb: Shocks Struts djpadko Classifieds: Want To Buy 2 14 Aug 2009 04:30 pm
Struts & Shocks djpadko Classifieds: Want To Buy 0 02 Jul 2009 03:18 pm
