Problems with the reverse light
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By rob342
Old 06 Jan 2013, 02:34 pm
Default Problems with the reverse light
Reverse light drama
I got a right hand drive euro 2ltr touring edn and am having a pain!! The reverse light stopped working for no reason ! Now i have checked bulb, fuse and switch on gear box all are working ok, i have power to the bulb socket when in reverse but the bulb just isn't coming on ! Any ideas as to why or is there a relay that i'm not testing in the loom ?? Or could it be the switch on the gear box
Old 06 Jan 2013, 03:00 pm
Default Re: Problems with the reverse light
If you have power to the bulb socket when it reverse, and you checked the bulb, the ONLY thing that would stop it from not lighting up is a bad contact between the bulb and socket. Check inside the socket for rust or anything that would stop the bulb from making good contact.
mityqwik likes this.
Old 12 Jan 2013, 01:12 pm
I've got the same problem with mine - registers 12v between the bulb holder connectors but bulb won't light
If you manage to sort it, please let us know how
Old 12 Jan 2013, 01:27 pm
with the engine OFF and the key in the run position, and the car on level ground, put the shifter in reverse. walk around back and wiggle the bulb in the socket. i bet it'll turn on as you mess with it. my turn signal would not work in back, the problem was the socket. it just didnt make a good connection with the bulb, when i'd twist/tweak/bend/wiggle the bulb it would work. when i let it go it would quit working again. sounds like you're having a similar issue.
Old 13 Jan 2013, 01:31 pm
Tried swapping the complete holder from the fog light - no joy. Could it be the switch?
Old 13 Jan 2013, 03:36 pm
Ray_Dockrey's Avatar
What year Cruiser?
Old 13 Jan 2013, 05:24 pm
Get wire and put power directly to the bulb from the reverse light wires. If bulb lights, it HAS to be the socket. I'm thinking the bulb has a broken filament that sometimes connects, sometimes is open.
Old 14 Jan 2013, 03:21 pm
Originally Posted by Ray_Dockrey View Post
What year Cruiser?
2004 - UK spec 2.2 diesel
Old 19 Jan 2013, 10:14 am
Thank you all for the thoughts on what it could be but have tried them all
It's a 2001 2Ltr petrol tourer
I have swapped the bulb and holder for the fog light still no joy ! I even skipped out the switch on gear box by shorting the plug and that didn't work ! I've checked the connection between bulb and mount, zip ! I checked all the fuses which are all ok, and connected the bulb straight to wires at the back so not the holder, All that is left that i can think of is 1 there is a relay in the circuit that is not working right or 2 the switch on the gear box need replacing ! So at the end of this month i am going with the switch so will let you know.
Reverse light issue neworder18 General PT Cruiser Discussions 17 10 Sep 2012 11:47 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
Problems getting into reverse gear! ProDigit General PT Cruiser Discussions 1 07 Dec 2010 07:26 pm
Reverse Light ptcruz311 Classifieds: For Sale/Trade 0 09 Oct 2005 01:10 am
BETTER REVERSE LIGHT FOR RHD westozpt Exterior Accessories Forum 0 20 May 2002 03:55 am
