LED turn signal light bulbs
Old 09 Jan 2013, 05:26 pm
Default LED turn signal light bulbs
Is there any danger or any foreseeable problem with replacing 3157 turn signal bulbs without installing a resistor? I mean...other than the fast flash?
Old 09 Jan 2013, 05:57 pm
Default Re: LED turn signal light bulbs
There's different types of LED bulbs out there. Some only give off the bright LED light in one direction so it would make it harder to see from the side. Make sure you look around at the different types of bulbs. Also some don't necessarily make the flash faster and are made to work like an ordinary bulb.
I have the Rocket taillights and changed the running/stop lights to LED's and the turn signal bulbs to halogen. None of them flash fast.
Old 09 Jan 2013, 06:11 pm
Thanks, these LED's are 360. These first two are white, just so I could see if they would work. I will be getting amber for the front & rear turns and red for the brakes. I'll move these two to the reverse lights. If I can find the right kind of resistors I will get them as a down-the-road-project.
Old 10 Jan 2013, 07:06 am
there is a how-to post on here on modding the the OEM flasher. It's piece of cake to do. I have LEDs in the brake & turn signals in the rear and regular incandecents in the front turns with no hyper flash.
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
Chrome signal bulbs beelsamin General PT Cruiser Discussions 1 05 Oct 2004 01:06 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
Turn signal & stop light gonzomania General PT Cruiser Discussions 12 25 Apr 2004 01:18 pm
Turn signal gonzomania Exterior Accessories Forum 12 30 Mar 2004 08:53 am
