Tranny Conversion: 2WD to AWD
Like Tree3Likes
Old 10 Jan 2013, 03:10 am
Default Tranny Conversion: 2WD to AWD
Yes, I know this is a costly idea so please save the "just sell it and go buy a Subaru" comments when I ask in all seriousness: could it be done?
My beloved '06 Cruiser is a 5-Speed manual transmission base model...and I love her. I have never missed a scheduled service and replaced most of the wear-and-tear parts at least once. Just went in for my 100k service and everything is running tip-top. BUT, I have a sneaking suspicion that my next major repair will involve the tranny as I have had to do nothing more than regular fluid changes and replaced the clutch a couple of years ago.
In addition to the threat of possible future tranny repairs, I recently moved from the deep south to the snowy north. The city plows are pretty good, but now I need something with a little more bite on the road. Good tires only get you so far up here...I want to turn my Cruiser into a little tank!
Question: Is it technologically feasible to pull a stock 5 spd tranny from my Cruiser and replace it with an aftermarket AWD transmission? I realize it would be a costly install (if possible at all), but if my other option is to trade up and just buy a 4x4, well that ain't cheap either.
Plus, how cool would it be to drop a Cruiser on a nice AWD tranny complete with a nice new set of fat nobby all weather tires? And while I'm at it, I'd love to install cruise control as well...the only real bummer with the base model 5spd.
OK, go!
Old 10 Jan 2013, 03:47 am
Default Re: Tranny Conversion: 2WD to AWD
OK, go!
yes.....and no lol
Is it possible to make a PT awd? Yes. Is it possible to do it with a tranny swap? NO.
What would be required of this task. Is to find a different motor, probably a 4cl/v6/v8 that is already 4x4 and a accompanying rear facing transmission that will accept a rear drivetrain.
Once you have those you would have to severely mod the vehicle, including the motor compartment, frame as well and remove your entire rear end, and replace it with a rear end with drive axles.
I would estimate the cost of this anywhere between $10,000 and $18,000.
I've actually never seen an AWD PT because of this issue, i've thought of it myself, but it really is cheaper just to buy a AWD than convert one. Also if you did this it would not really change the value of the car so when you went to re-sell it 90% of your costs would be pure loss.
Old 10 Jan 2013, 08:00 am
mikelikestobike's Avatar
Anything is possible, given enough time and money. This sounds like a cool idea, but would probably be insanely expensive.
'03 Manual non-turbo in Silver w/ Factory flames.
K & N Drop in, Modded airbox, MSD Superconductor wires, Strut bar, blue dots in taillights. Sold 12/13
Old 10 Jan 2013, 09:58 am
Did Chrysler ever offer a awd with the 2.4 in the minivan. I know they did in the v6 but only in the automatic. A good machinist should be able to make that work. Would also need the rest of the drive line from the front transaxel to rear end. Floor pan would need a tunnel for drive shaft.
Old 10 Jan 2013, 10:39 am
Default consider a 4x4 conversion instead?
It is not a machinist but someone that does Drive-train conversions. There are a few of shops I can recommend that do this. To convert the running gear the labor would be around 2-5k. Then you would need a good body shop and upholstery shop that does custom work, so another 3-5k. And then there is the actual running gear parts, ka-ching another 5-7 k. So ya about 18k would do it just nicely?
Below would be a cheaper project and there have already been several conversion, so lot of information available.
This is in our own forum:
Custom PT Cruiser 4x4
Last edited by NitroPT; 10 Jan 2013 at 01:13 pm. Reason: changed title for clearity
Old 10 Jan 2013, 10:43 am
cheapest way to go 4wd would be to drop the body on a truck frame
then, to make it unstoppable in the snow, buy these:
Old 10 Jan 2013, 10:48 am
I beat you to the post!
slam.....by 4 minutes!
rob342 likes this.
Old 10 Jan 2013, 12:19 pm
Guys I was talking about still looking like a pt. Not a monster truck.
Old 10 Jan 2013, 12:23 pm
Originally Posted by NitroPT View Post
This would be a cheaper project and there have already been several conversion, so lot of information available.
gotta read what I post?
Old 10 Jan 2013, 12:48 pm
To read your post with the pics provided would lead anyone down the path I took. To do otherwise would require me or others to know what your thinking. only with the last post as a clue was I able to separate the two thoughts.
RWD Conversion? beansracing Tech & Performance Forum 12 15 Jun 2013 02:18 pm
New Conversion TheRed Welcome New PT Cruiser Members 6 26 Jul 2011 10:20 am
CNG conversion? georgespt Tech & Performance Forum 6 06 Jul 2011 10:51 am
conversion to Gt PTcruzer02 General Turbo Discussions 18 04 May 2009 02:04 pm
HID Conversion Kit Sam2627 Exterior Accessories Forum 2 26 Jan 2008 02:36 pm
