error code p1701
Like Tree2Likes
  • 1 Post By mnahmnah
  • 1 Post By CREWZIN
Old 11 Jan 2013, 05:56 am
Default error code p1701
PT Cruiser 2 ltr 2001 limited edition, manual shift.... Engine has coughed a bit on start up for a couple of days and today the engine warning light came on and the error codes are 1684 and p1701. I know 1684 is a nothing.
P1701 says Trans. MIL Request Circuit... but I have no idea what this means in English.....Any help anyone?..... Thanks
Old 11 Jan 2013, 07:27 am
mnahmnah's Avatar
Default Re: error code p1701
All I know about that is Trans = Transmission, and MIL = malfunction indicator light (your check engine light).
I'm sure someone more knowledgeable will be along soon to fill in the gaps. I have the same car, same year, same issues right now, but no codes... good luck!
Busted_PT likes this.
2001 LE, 168,000 miles.
One of the split seats went into a dumpster in Tulsa. The arm rest unscrewed and fell off. It's on its 2nd timing belt. Surviving the Upper Peninsula winters.
Old 11 Jan 2013, 07:30 am
Thanks for that its a start and puts me further forward than I was
Old 11 Jan 2013, 09:11 am
Looks like you need to take it to a shop with diagnostic tools for further information.
P1700 - Transmission Control Module (TCM) problem this means there is a proprietary code stuck in there, set by the transmission computer; it could mean a bad sensor. This can only be diagnosed by Chrysler-specific tools, which some shops outside dealers do have.
P1701 Trans. MIL Request Circuit
Old 11 Jan 2013, 10:15 am
Must be a speed sensor. Didn't know a stick could give a code. Not worth a $200 bill to fix a $20 buck speed sensor.
Old 11 Jan 2013, 10:21 am
Might want to reset the computer. Take the negative battery cable off for about 5 minutes. Step n the brake pedal to get rid of any residual charge. Put it all back together and see if that clears it up.
Old 11 Jan 2013, 11:24 am
Unfortunately this might be something the dealer will have to diagnose. I can't find either of those codes in Chrysler's master code list for a 2001 2.0 liter.
I was going to look at Chrysler's definition for the code, but it's not in the list...
-Chris
Old 11 Jan 2013, 12:15 pm
Is it a 2.0? Or maybe a type o.
What does the error code PO 138 really mean? TheFox General Turbo Discussions 8 15 Jul 2012 10:10 pm
error code 113 BeagleDad Tech & Performance Forum 17 22 Aug 2010 01:13 am
Error Code bds02pt Tech & Performance Forum 2 29 Jan 2010 03:01 pm
error code... superpug666 Tech & Performance Forum 16 13 Oct 2009 07:33 pm
Error code??? russ00001 Tech & Performance Forum 0 29 May 2007 04:24 pm
