All motor builds
Old 12 Jan 2013, 06:55 pm
Default All motor builds
I was just wondering if anyone here has done an all motor build to their PT. Just looking for what you did, where you got parts, how difficult was it, rough cost, and anything else you wanted to include. OH, and rough 1/4 times if you have them.
Old 12 Jan 2013, 07:01 pm
Default Re: All motor builds
No need to do all that if you have the High Output Turbo Cruiser. A few small things and you can be running in the high 13s.
Old 12 Jan 2013, 09:53 pm
There is only maybe two(?) complete performance long block builds posted on any PT forum or other closely related forum that PT owners are member's.
There are numerous postings of PT owners doing various degrees of stock and semi stock engine rebuilds. You just need to look around this forum and other forums to find them
Otherwise your question is impossible to have the same frame of reference unless you live in the same area as some who have done a long block rebuild. Labor on machining the block and head as well parts vary from state to state and town to town. Where ever you live this would be a better question to ask at your local engine machine shop.
As a Drag Racer of many years I can assure you that 1/4 mile times and trap speeds depends on to many factors not all the least of changing a few parts and duplicating what others did. Results vary!
If you want to go quick in the 1/4 then buy a pair of PT NA steel wheels mount some slicks on them and buy a Sniper NOS system. $600 will get you in the high 12's mid 13's the easy way.
Teska likes this.
Old 12 Jan 2013, 10:50 pm
Well I was speaking to my friend, hes a neon specialist, and he told me for about 6k for all high end parts, i can get it down to 11-12s. hes doing the same for his dohc neon
I have a n/a pt, and i didn't want to go to the turbo side, too unreliable, id have to put premium gas in it, and its a pain in the arse to find a good turbo engine.
I live in ontario canada, so that is why its a little more difficult to find parts.
Old 12 Jan 2013, 11:01 pm
Well sounds like you have your answer and a friend that can help you?
Good luck !
Old 12 Jan 2013, 11:19 pm
hes busy with his own builds, he has a sohc that hes turbo'd and a dohc that he is doing all motor. Im a mechanic by trade, but im going to have to send the block and head out to get the pistons installed and the engine nice and clean. i can install the cams myself, and the valves myself, just the pistons/rods i need the tools that i do not have. i might be able to ask my college to help me out:P
Old 13 Jan 2013, 03:47 am
UptownSport's Avatar
$6k on your engine?
What, exactly, do you plan to spend that on?
LOTS of guys do all motor 2.4- If you get some 18's or 21's I hear they work well-
However, once beyond that valve spring choices are limited.
Once you get into custom parts your life will become HELL-
2.4 has a very long stroke- so valve area is small relative engine size.
Doesn't seem to matter if it's turbocharged but N/A is a diff story
But don't even talk about the engine- How much weight are you willing to pull to do these 11-12's? totally gutted, undercoating stripped and cutting?
If no, then you can't get there from here.
Old 13 Jan 2013, 09:23 am
heres the message he sent me
Header $80, CAI $40-60 used, ecu or custom tune$80-500, fuel rail $80-150, injectors for more fuel $40-80, walbro 255 fuel pump $50-120, 57-60mm throttle body $20-100, INDY intake manifold $200-500, msd ignition with wires and plugs $50-150, cams $150-500, muffler or exhaust $50-200, rad fans and cooling system $100-400, thermestat $20-100, manual or key on rad fan switch so you car runs cooler $10-20, high compression pistons and rods$600-2000, valve springs and titanium retainers $200-400, 5 speed transmission $150-300, 5 speed axles, hubs, bearings, peddles, cables, shifter, rpm tach $400-600.
seems like a good plan to me
Old 13 Jan 2013, 09:44 am
thermestat $20-100,
I would go for the low end thermostat. Just as good as anything gold plated.
Old 13 Jan 2013, 12:22 pm
CREWZIN his prices are all over the place no sense to them and not well thought out??
Uptown the valve springs are only limited to you all!
6k for a pro built performance long block is not unreasonable but here again his last post about where he is spending the money does not really seem to count that?
Post #3 seems to be the best advise here?
New motor jaypee Tech & Performance Forum 2 25 Nov 2012 06:32 pm
how old is the 2.4 motor crazyptguy Tech & Performance Forum 4 24 Feb 2012 02:34 am
05 Gt motor into 03 GT Coopsta454 General Turbo Discussions 1 23 Nov 2010 03:17 pm
Which Motor Oil PTNoob01695 General PT Cruiser Discussions 18 24 Aug 2009 08:42 pm
fan motor rrrperry Tech & Performance Forum 3 31 Aug 2004 09:06 pm
