Timing belt
Old 13 Jan 2013, 01:45 pm
Deepstar's Avatar
Default Timing belt
I week ago, I pulled out of a friends yard and got up to 50 mph and lost power. I let my foot off the gas and coasted to a stop. My question how many owners have had a timing belt break and it bent valves?
Old 13 Jan 2013, 01:57 pm
Default Re: Timing belt
2.4 L engines are 'supposed' to be non interference, ie NO contact between valves and pistons ever possible no matter the (mis)timing, under ordinary circumstances (realistic RPM operation, conds. below insanely extreme revs causing valve float or bounce)
I think 2L are interference , guaranteeing bent valves after a belt break.
( what PT uses a 2L ? old or ex-US ones ?)
That said I looked a job ticket at a Chrysler Stealership last week for a broken belt repair (~$1500 with water pump) which claimed "possible valve damage" with no other explanation, you think they would know better than lil ol me.
PS if they put a belt on MY car with valve damage present, I would sue their pink lil pooters for malpractice. Its like given me a heart transplant sourced from a cardiac related death
Old 13 Jan 2013, 02:41 pm
The valves can collide when the belt breaks - it doesn't happen often, but it can happen.
I don't know how you can tell if the valves have hit.
Old 13 Jan 2013, 02:58 pm
point well taken - didnt think about valve to valve relations.
“The 2.4 Liter (148 cu. in.) in-line four cylinder engine [has] hydraulic lash adjusters. The engine is free-wheeling; meaning it has provisions for piston-to-valve clearance. However valve-to-valve interference can occur, if camshafts are rotated independently.”
The 2.4 liter four-cylinder Chrysler-Dodge engine
Old 13 Jan 2013, 02:59 pm
Deepstar, your asking the same question that you already received answers to in your other post. What gives?
P1391 and P0340
Old 13 Jan 2013, 03:39 pm
Deepstar's Avatar
Hoping to find someone that a had same thing happen to them that's all crewin. All the details count...
Old 13 Jan 2013, 03:45 pm
Tons of old posts on subject. Many first timers are in the same position. There is an on going post right now.
Old 13 Jan 2013, 05:19 pm
checking for consistency???
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Timing Belt ptnut Tech & Performance Forum 6 27 Nov 2011 11:38 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
