04 PT starter issue
Old 13 Jan 2013, 07:21 pm
Default 04 PT starter issue
i have a 04, that the starter acts up (more like a drag) the first start of the day but after that, it turns over and starts fine, the battery is new, and the charging syst has been checked and is in good shape.
does this sound like a solenoid issue ? or ?? like i said this only happens during the first start of the day, there does not seem to be anything draining the battery because even if i let it sit for 4-5 days it does the same thing as if it were just overnight.
thanks.
Old 13 Jan 2013, 08:01 pm
Default Re: 04 PT starter issue
It could be. bad news though bub, the starters on these are solid, cant just pop the solenoid out and fix it, have to replace the whole thing.
Also where are you located? anywhere cold? if the temp is under 40*F the engine will crank a lot slower during starting, this is because the engine is basically frozen , the oil is extremely thick *like molasses* and it just has a bit of trouble :-)
Now if it is doing this in the summer, replace the starter. :-)
Old 13 Jan 2013, 08:16 pm
well that may be it , it has been cold and in the morning, it has been around 37 or so,
Old 13 Jan 2013, 08:23 pm
that could very well be it, look into buying a heated oil dipstick, can get it at carquest,napa etc. basically keeps your oil warm in very cold weather,thus keeping the engine warmer, thus making starting easier. usually under $30 :-D
Old 13 Jan 2013, 08:43 pm
cool thanks for the info.
i think its the starter 420pt Tech & Performance Forum 21 19 Mar 2013 02:21 am
starter maybe? Bonecruiser Tech & Performance Forum 11 03 Jan 2013 05:34 pm
Starter Issue... Any Suggestions? FancyC Tech & Performance Forum 6 15 Feb 2012 09:44 pm
starter? jmikesch General PT Cruiser Discussions 5 07 Jan 2012 02:15 pm
Possible bad starter morrises Tech & Performance Forum 7 17 Jun 2008 09:07 pm
