ecu-pcm diagram
  • 1 Post By Ray_Dockrey
Old 14 Jan 2013, 02:10 pm
Default ecu-pcm diagram
hi every one,i have an electric problem with my 2006 limited pt, yesterday when i started the car every thing went fine exept the lighting gauges rings and the sterio lights didn't light up, the car is working fine and the gauges are working exept the green rings light dont work, i tried to check every thing i did not fined the problem checked the fuse box under the hood every thing is fine, i thought its maybe a problem with some wire coz i have also lost all the lights that come up from the first key tik,if you know what i mean the first move from the key before you turn on your engine as i noticed later , so i am looking for ecu-pcm diagram, i found and ecu-pcm diagram for limited 2006 does any one knows if its the same as my 2006 car?
thx
adam
Old 14 Jan 2013, 03:10 pm
Ray_Dockrey's Avatar
Default Re: ecu-pcm diagram
Just to make sure you don't have the dash lights off do you? Its easy enough to do and not realize it.
Old 15 Jan 2013, 09:27 am
no the swich is on i turn the handel and i pass the click when the dash should light but it wont and then complete the round and the head lights turn on, i think its some wire problem,maybe i am not sure.
hope you understand what i mean, sorry if my english is not very clear
thx for every one try to help
Adam
Wiring Diagram clint21anne Tech & Performance Forum 10 24 Jun 2012 11:44 pm
fuse box diagram joyjoy Midwest PT Forum 6 09 Jun 2012 04:04 pm
Diagram on how to take a Turbo in and out? Petey2506 Tech & Performance Forum 4 26 Mar 2011 10:20 pm
A/C diagram windsblow General Turbo Discussions 3 19 Jun 2010 03:30 pm
Need Diagram KingKole02 Tech & Performance Forum 5 24 Jan 2006 09:09 am
