Fog light problem with smoke
Old 15 Jan 2013, 12:21 pm
Default Fog light problem with smoke
2003 PT Cruiser limited, 83,000 miles.
Had a problem today, rather alarming at first. Driving home in daytime, no lights on, the front fog lights came on by themselves and would not turn off. After a short while alittle smoke started to come from the top of the steering coloum around the hazard warning lights button. Thought the car was going to go up in flames. After stopping and playing around with light switches etc the smoke (which was only wiffs of smoke nothing major) stopped. Since then all electrics/lights seem to work ok as does everything else except the fog lights.
Any ideas? Im no good with electrics but am thinking along the lines that something may have shorted out. All advice welcome.
Many thanks
Matt
Old 15 Jan 2013, 12:23 pm
Ratdaddy's Avatar
Default Re: Fog light problem with smoke
It's a short in the multifunction switch .Replace ASAP...Go here Replace Multifunction Switch w/fog lamps
Old 15 Jan 2013, 12:27 pm
As Ratdaddy, said, short in the electrics of the "multi-Function" switch. A know problem with the PT Cruiser. You can replace it for about $70 or if your handy with tools, try and repair it yourself. Here's the llink:
How to Repair the Multifunction Switch w/ Pictures (Fog Lights)
Old 15 Jan 2013, 12:29 pm
Is this known as the mulitfunction switch? Ie the stalk that comes out from the steering coloum that turns all the lights on and off?
Thanks for quick reply
Old 15 Jan 2013, 12:35 pm
Ratdaddy's Avatar
Yep you got it..
Old 15 Jan 2013, 12:39 pm
Many many thanks guys. Very much appreciated. I'll get onto it
Old 15 Jan 2013, 01:08 pm
I bought the car 2nd hand about 2 years ago. Ive just looked in the fuse box within the car and noticed that there is no fuse for the fog lights. So I would assume this has been a problem for the previous owner that has now come to a head. Never having used the fog lights I did not notice (and nor did the mot inspector) that they did not work.
Old 15 Jan 2013, 01:23 pm
Saying that the MOT inspector didn't realize the fog's didn't work must mean you from the UK (unless the EU has MOT inspections also). I spent 12 years in England and I know the MOT was something to dread if you had an older car.
True they didn't make sure everything worked but what they did look at, they sure gave a close inspection. Even surface rust on parts that were normally in great shape could cause you to fail the test.
But your multi-function stalk has nothing to do with that. Quite a large percentage of owners have had to fix or replace that stalk.
Many owners who bought the PT used found that the No#8 fuse in the interior fuse box was pulled because most of the time, when the stalk failed, the fog lights would stay on and run down the battery. It was easier for some to pull the fuse than fix the stalk.
Dash light problem sgfout Sound and Security Forum 2 09 Oct 2012 10:42 pm
Help!!! smoke and belt problem webstertroy General PT Cruiser Discussions 5 28 Sep 2012 06:33 pm
Odd MIL light problem Ghost Tech & Performance Forum 6 02 Oct 2011 03:01 pm
oil light problem HELP DPHC General Turbo Discussions 21 14 Aug 2010 10:46 am
Dome Light Problem Johns Steel Blue General PT Cruiser Discussions 2 21 Aug 2007 07:51 am
